Aps 6384… They are quite open
Oh that, yes that’s the stator. You can cover that with 422B yes it will help prevent further water/contamination damage.
Just remember that’s the part that gets hot.
So’s this. I assume it cures via solvent evaporation or air contact or something.
https://www.amazon.com/Epoxy-Insulating-Coating-12-5-Aerosol/dp/B004RH4ZG2
I’d offer to send you a can since I’ve got more than a dozen, but hazmat.
Those aren’t the magnets bruh. The magnets are the shiny things inside the spinny part.
Wow I don’t even know how I would handle a giant aerosol can like that. I use a tiny, tiny brush to meticulously get it in there and all over everything – except not the things I don’t want it on.
That’s like a blaster cannon, cover the whole room LoL.zzz
Seriously? I thought they were both magnets? What makes them clamp together then?
Masking tape all over everything you don’t want covered, then let 'er rip!
Don’t get ANY 422B in any bearings. It’s not a good time. Take the bearings out if you can first.
Steel sticks to magnets…? That stator is made of steel?
The coils make it into an electromagnet, but only when it’s got electricity running through them.
oh they are steel! i didn’t know
For delicate work I’ve also sprayed it into a cup and then used a brush/cotton swab to apply it from there.
Steel is what rusts bruh.
Yeah when each coil turns on, it turns that “prong” of the stator into an electromagnet which then pulls on the can to line up one if its magnets with that prong. Continuously rotate which ones are turned on, and the rotor will keep trying to catch up, causing a spinning motion.
bruh
Can PU wheels, like TB110, be fitted onto MBS matrix 2 trucks?
Is this a bad idea for street riding at ~20-30mph?
Yes they can with the right bearings.
Not a bad idea, matrix trucks are nice and wide so you’ll be pretty stable at speed. Turning circle might be a bit large though.
Does anyone else have any ideas here?
Hi everyone, in the past few days I looked on the internet for a pair of 6365 190kv Maytech motors, I don’t want to order them from Maytech.com because the shipping is too expensive (50$)and they don’t respond me since I kindly asked for a little discount. Researching online I found them on alibaba at pretty good price but I’m afraid of the reliability of the shipper. Do you know where can I buy some legit 6365 190kv motors? Is there any other good option besides Maytech?
I HAVE A PAIR OF 6365 190KV. They’re the closed can version. These ones
Buuuut, I cut the shafts suuuper short and they’re more than likely unusable unless you’re able to find replacement 8mm shafts
Dude wytf you did that??
