Hi all
I have 2 vesc 6 master is 0 slave is 1
Ack is loaded
I plugged in my vx2 set up Id o uart 115200 working and wheel is spinning
Went in to vesc 2 slave I can see I’d 1 uart 115200
But when I push trigger only mater vesc is spinning
yes its set to true
Master “Send CAN Status” should be False
still not working i will reload the firm ware and start all over
still not working
I don’t know what to suggest, try swapping which ESC is the master and has the remote connected. If that doesn’t work, maybe try a newer firmware like Vedder / 5.1
Anyone else have any ideas?
I swapped already
do you have a link to 5.1 i cant find it
can split he uart cable to the two vescs
