Little info on the side: shoulders can be removed with a pair of pliers, they are only pressfit. But then I think you might have the belt wanna fight the bolts
Call me crazy but I really like the way Boosted did braking/reverse and I aim for that on all of my builds. I live in a dense city and fast/powerful reverse has saved my ass a couple times.
hmm. this is not what it did fo me. it seemed to jump to fixed duty cycle. so it was either way to slow or it tried to peel out if you upped max duty cycle. maybe I have misunderstood it.
After installation of davega X into friends Trampa (2x vesc6+), his vesc with davega loses power sometimes during ride. This is irritating, even dangerous because his brakes are much weaker with only one wheel drive.
Sometimes he has to power off and then back on his vesc to get it working, sometimes it starts to work by itself. We did motor detection/setup once again, nothing changed. All wires and solder joints look good. Where could be the problem?
boosted is the same as “current”. ie full reverse.
some drawbacks are you can spinout while braking. loosing traction.
panic braking can result in reverse shootouts.
people not used to reverse will also result in reverse shootouts even without panicing.
still i’ve used it for lack of a better option say on stock unity firmware.
1.7s smart reverse ramp up time, 7% max duty cycle. I find that getting it to accelerate too fast makes it either cog while still on hall sensors or just take me by surprise with the torque
Yep. That ramp time is definetly a problem. Default is 3s and it’s slooooww. Try 1.5, 7% duty.
Do note that letting go and braking again, first brakes, then ramps up smart reverse again. Also forward brakes, then starts forward automatically. No negative erpm bugs here as far as o know
