Happens to me too. Do you put all your weight on your rear foot? Usually, front feet should have slightly more weight if not most weight.
What I do is carve more actually. I know nothing about physiology or body mechanics, but when at a static stance, the muscles in your feet are just building up lactic acid. When you carve, youre cycling through different muscles instead of just the same ones.
I try to move my weight to the front foot when i remember, but my body defaults to a upright position and i have to activly think about moving my weight to the front foot
And i find it a bit scary to have most of my weight on the front foot
It’s for sure different for some people because of how they ride. Sorry I should have stated that. For example, it does not make sense for someone to have their weight on the front foot if they’re applying torque. That’s almost physically impossible because your rear foot is acting as a brace. So if you’re frequent with throttle and torque, then it makes total sense if you’re not accustomed to it. But for long distance, steady state high speed riding, (which for the record most people don’t actually do here) front foot stability is key
IN THE END, where your weight is doesn’t matter for most people but to avoid foot fatigue, do the carves
No no, all good. Just like not everybody can fit the same shoes. Just wanted to give my input
Isn’t that exact what people are supposed to do?
Accelerate = lean forward
Brake = lean backwards
on second thought: lean ≠ weight
Thats what i can do. When pushing the throttle my weight is in the front, but when cruising i’m especially back heavy instead of distributing it equally.
For eMTB LiPo builders: what’s your go to battery enclosure?
I have 4 6s packs from TURNIGY in need of a good protection while I learn how to fall in the forest.
I imagine pelican 1200 but don’t want a case too big or too small. Measuring always screws me over as they don’t state their internal dimensions correctly due to rounded corners
I would say if you go for the Pelican 1200, go for the Pelican Storm iM2050. Its better quality imo and has latches with buttons. Also the listed dimensions are pretty accurate.
The ESCs are supposed to be in parallel, not series. One black wire on each ESC goes to battery negative, and one red wire on each ESC goes to battery positive.
