Wrong category my guy?
Puck if you have METR/HM-10 or a DAVEga
Clearly about to start a battery build. Read between the lines.
Haha touché
I didn’t chose the category,I put “deck “ in search category and it’s just did this
What ESC does the Exway Flex use and has a comparison been done between that, and say the Unity?
latest hobbywing proprietary 12s esc
ah ok. how does it compare to other ESC’s of it’s class, perhaps something in the Maker-X series?
hobbywing isn’t a bad esc per se, but with it being a proprietary esc, there are not enough data to compare it with other vesc of its performance / software settings.
However, the standby feature is too convenient.
The standby feature is incredible, i just wish some bastard would clone it for us.
that feature drain about 2% per day on my exway x1 pro, I doubt most people would want that especially when some of us are using loop key as safeguard.
tempted to just get an exway
it is possible to build ur own diy using hobbywing esc, but u will be missing out the vesc goodies
Okay I’m about to give up trying to find a coyote or kut-thaka deck. Does anybody know if @eBoosted enclosure fits the omakase? Because I have that as a manual deck and I think I’ll just build off of that
‘nother noob question: what’s the difference between calibers and ecalibers?
Axle length.
ECal extended for pulley bearing. Apparently prone to bend tho. You can cut back hangers on a standard clover to make do, without the extra length if needed. Boardnamics 184 is a precision alternative with stronger axles
ecaliber trucks have longer axles, this allows you to use push-fit / press-fit pulleys with them, because those pulleys take an additional bearing. Slightly more expensive, but means your pulleys will always be aligned!
Ecalibers are worse. If you need extended axles, either cut down a regular caliber or buy Boardnamics’ 184s. They’re almost the same price and much better.
Yea it’s just a bummer that u can’t really fit 15mm belts on the normal calibers and the 184s aren’t widely available used for sale
Edit: taking into consideration that I’m in the eu makes the whole situation even worse cuz of the tax and shipping costs
Dual 15mm belts is possible.
