Do parameters save on each type?
I mean, i do bldc detection, save, ride, go back and switch to foc. Do i do detection one more time? (Using android app)
Yes, No,
once you detect and save the FOC detection you can switch to FOC anytime without detecting again
once you detect and save the BLDC detection you can switch to BLDC anytime without detecting again
Well anyway, that’s using a PC with the Linux build. I don’t know anything about doing it on Android, but it’s probably similar. Just look at the numbers.
Is it normal for the wheel to still spin from inertia between the first and second part of the detection? Anything over 2A sends it flying for at least 4 seconds
I have silicon covers on my direct drives I the glued a thermistor to the back of the motors there is a slight increase in temp. I also have vinyl on my shortboard motors to protect them. I run these 6354s hard no issues with temp.
I have a DD 75KV running 12S and 150mm wheels it’s super fast over 60km/hr but not as torquey as my other boards it will get up a 15 degree incline but struggles on steep hills. A belt drive I would just gear down. A DD the only thing you can do is reduce your wheel size. I am keen to try the new 5" pneumatics they will shave a few mm of my wheel size. On 107s I have plenty of torque and speed is still awesome.
hey is thier a way to extend the cut motor wire its just just to much tenshion and i think im going to run in to issues later ? any idea what size or somthing like that ? it need like a quater inch of cable
What’s an inch? Oh, you mean a quarter of 25.4mm? So, like 6.35mm - ish.
Generally, under most cases, wire size is determined by how much current it needs to carry. In isolated cases where the amount of current is ridiculously small, you may want to select by physical strength (example: wires to RC receiver)
