Does it happen when U change UART ports?
Not opening my enclosure again to check
I have just spent like 10min putting in all the bolt
Also upgraded to m5 bolts and inserts and they are so much better
What could be the cause though?
Told you M5 is da shit…
One vesc starting up faster than the other…
Could be a faulty cap, or bootloader problem
Ah so if I turn it on and wait like 30 seconds then should both motors spin?
Thanks
Reflash your bootloaders
Will do next time I open my enclosure
Thnaks a lot
Anytime brother, hmm sister, whatever you identify as…
A blue post box
Blue Police Box?
With that title it sounds like I’m the one to blame
6$ is what a shitty shop offered as a refund for a 100$ vesc purchase with defective units
I want my:
A secret mystery word like Llama
Title back so hard
Can’t live without it
How dare you…
Please change it back
First build here - looking to setup my ESC before i finish this thing this weekend.
Flipsky Dual 6.6 - what do you all recommend for the VESC firmware version? Is the latest one stable? I believe my flipsky was shipped with 4.2 on it already
Ackmaniac
Thanks for the input, the ackmaniac how to thread is almost a year old (How to: Ackmaniac ESC Tool) -
is the download link in this thread still the most up to date FW?
Also, just to confirm - this can still work with Metr Pro correct?
Yes and yes. The Ack project is frozen. 3.103 is the latest fw and it works perfectly with Metr
I use it on all my boards
yup like 6.35mm
Does the ackmaniac android app work with normal vesc fw?
Who is the man to go too about range extenders?
I was gonna build a massive pack and slap it on my board, but I have been thinking about it and I won’t always need that crazy range.
Hi guys!
I’m very new to esk8 and I just made a wiring diagram (it really looks silly, but it works for me) for my skateboard with bypassing the BMS since I have a BMS for 30amps. I was wondering if you guys could tell me if I did it the right way before i start soldering everything together.
Greeting,
Bas!
I just discovered I cannot ad images to my posts so I’ll guess I have to wait till i get the permission to do so.
