Good point, it does show elevation on apps like Relive. But does it use elevation to adjust speed calculations? Pretty neat if it does
I would assume so. If you think of how a GPS works, it triangulates the point in 3D space, so when you compare two points in 3D space the Z axis would automatically be factored in the distance/speed calculation.
Looking online, most GPS do not account for the change in elevation. However, even if you were dropping 1km in elevation over 5km distance it would only make 0.099km difference. Which is a 2% variance. Looking at the variance you mentioned this wouldn’t explain it. I’ve also had the same issue with variance. You could find a long flat road, check the distance on a GPS map and then ride it a few times up and down and look at your remote distance. Based on how inaccurate you could adjust your wheel diameter by a mm and retest.
This would show some dedication to getting accurate distance/speed measurements though ![]()
sorry, what I should have said, is whilst the GPS does account for elevation, most apps do not use this to calculate the distance more accurately
and yes, i do have too much time to spare ![]()
I recently purchased the BKB Type-R. I mostly ride with the pneumatic wheels. I’m curious anyone knew of some different motor mounts I could buy that would be compatible with a bashguard kit/ current motors to sort of act like handle bars for carrying purposes. This is my first belt driven board so I am a little ignorant on where to look for parts. I hope this is the right forum to ask this question.
What trucks are on the board?
The trucks are their version of Caliber 2. Almost exactly the same in every way, but the back truck has a shorter hanger.
What foam is the best to use for the enclosure, I’m currently adding a thin layer of high density EVA foam on the bottom and one on the bottom of the board to seal the enclosure and add some padding on the batteries, have a thicker foam that’ll be around the lipos, do I need to worry about the foam catching on fire when the boards in use due to the batteries heating up
If the pack gets hot enough to ignite any foam then you have much, much bigger problems than the foam igniting. Your cells will certainly be on fire, pretending they’re model rocket engines. ![]()
The foam shouldn’t even get hot. In fact, your pack should never even get past a bit warm as that would mean the cells in the center of the pack were already getting pretty hot.
Any closed-cell foam (to not absorb water in case it gets in) that does not “set” (stay compressed) can work as long as it compresses to about 50% when the pack is bouncing around. Much less compression than that and the foam is probably too stiff, transmitting more vibration to the pack. Much more compression than that and the foam could “bottom out” and the pack hit the enclosure.
yep
Some people use silicon for their packs, I see absolutely zero point in going through that pain, when you can just use black hotglue
your pack should NEVER get hot enough to melt hot glue
thx…I guess it is true, lol
On the website of lacroix they wrote that the range of their board varies with the gearing, with the same battery, esc and motors. Why does a higher teeth number on the motor pulley increase my range? (It´s about belt drive btw.)
Short answer: it shouldn’t change that much
Long answer:
larger motor pulley → less belt flexing → less resistance → slightly higher range
larger motor pulley → motor has to spin less fast for the same speed → decreased core losses → slightly higher range
smaller motor pulley → less motor current needed to accelerate at the same pace → slightly higher range
smaller motor pulley → smaller top speed → less wind resistance → slightly higher range
Maybe there’s other factors I’m forgetting. But yeah, it can go either way, although usually it’s the higher speed and decrease in acceleration per current that end up being the largest factors, so range usually tends to go down as you increase the motor pulley size.
Why don’t we use ferrite rings on phase leads?
Because as far as I can tell, they’re generally unnecessary?
Why do you think we should be using ferrite rings on phase leads?
Well it would prevent Crosstalk but I’ve asked @b264 about this and he claims crosstalk is a non-issue, and I can confirm that as my phase lease are tightly zip-tied together and I’m not getting crosstalk issues.
