b264
June 10, 2020, 9:36am
#758
That’s exactly what I’ve been needing this whole time, a kickstand for my skateboards.
I am going to move to china and help them with this crap…
No kickstand not for skateboard!!!
Let me know if you need help with your Kickstarter.
honestly 4 wheels isn’t very stable
but next payday I’m buying 8 gummies, I’m hoping that should do the trick
pekkas
June 10, 2020, 10:01am
#762
Hey Guys, Noob all over here! Decided to build my own DIY board. However being UK Based we have poor roads, poor pavement and shitty police. Which means I have decided to give up on my 80mm kegal wheels and look at getting some SR Foamies. However I have been told by SR that I will need an adapter for my caliber 2 Trucks to fit their wheel. Would anyone have a clue where to find the adapter to get my conversion done?
Don’t buy SR foamies. They’re still selling the defective core.
More info here:
Hey all-
Since it appears that there are some real issues with the core quality on these wheels, please make an informed decision on whether or not you decide to buy/ride them. More information can be found here at the tail end of this thread:
The riders affected have reached out to iWonder with good results, so we may see an actual solution from them. Hopefully it’s a switch to a Kegel core or a big leap in core design of some kind.
A few photos:
[image]
[image]
[image]
[image]
And here:
Hey all-
With the launch of a new version of Cloud wheels/Foamies with a beefier clear core and the name “Discovery 120D”, let’s talk about them here to limit the confusion with the old version. For clarity, the Discovery only comes as a clear/translucent core.
If you have a pair like our friend @BluPenguin , please share your thoughts on them. Credit to @Hide from iWonder for stepping up and keeping us informed and supported as we transition to the new wheel with an improved core.
pekkas
June 10, 2020, 10:06am
#765
I have read a few posts about their core. Would anyone recommend an AT wheel I can add to my trucks?
Such a huge range/topic. Start here:
The Goal
I’m sure you’ve looked at a wheel and thought :
. . . What pulleys fit this wheel.
. . . What bearings does it take.
. . . What is the bolt hole spacing.
. . . is it compatible with . . . .
Most 3.75" Hubs can fit 7" 8" and Trampa 6.5" tyres
Possibly TB 6" Tyres
2.8" Hubs fit 6x2" tyres exclusively (Bergmeisters and Sixshooters)
After my frustration trying to find some AT wheel related information, I decided there should be a central place where this information lives.
The goal …
5" pneumatics from hoytskate
Hi anyone know what this noise is
It only comes from when motor
b264
June 10, 2020, 10:22am
#771
Is the belt on? Does the noise happen with it off? Sounds like a belt way too tight followed by a slipping grub screw on the motor pulley, but this noise alone makes is hard to diagnose.
b264
June 10, 2020, 10:23am
#773
Switch which ESC it’s connected to, does the noise change sides?
What are the results of the BLDC hand test?
Sometimes if you’re buying used, or troubleshooting, and need a quick way to see if anything might be wrong, you can test a BLDC motor with only your hands. It’s not the most accurate test in the world, but catches most problems.
[f5c1e17e62e9f244432bf763be93746978c88931%20(copy)]
Ensure motor phase wires are not connected to an ESC or anything else.
Verify the motor spins without grinding or rubbing. Put a tad of sideways stress on the shaft and push it and pull it (while turning) to veri…
Does it happen with no wheel or wheel adaptor?
Good call will try that now
Have had some issues with this vesc so gonna look into that
When did you last lube you motor beatings
Uuh never
There are 2 bearings and don’t have any lube
Can you link on amazon
Confirmed it def isn’t the can might be stator vesc or bearings
Can I use wd40 as bearing lube
Or bike lube?
