New version 84V/200A VESC motherboard, using INA241! testing!
Yes, as the title indicates, I am testing the new VESC motherboard, and the test has been basically completed. In this post, I will only share my process of designing the motherboard, without attaching other links (after the company sells the motherboard, he will provide the schematic diagram Or the PCB files may be released).
I named this motherboard 84200HP (because the design was based on Benjamin’s 75300, I originally planned to name it 75200, so there was a silk screen of 75200 on the PCB, but obviously 84200HP is more suitable for it). The following are the current parameters of the motherboard:
  1. Use INA241A2 high-precision sampling chip;
  2. Use 12 MOSEETs (100V/380A);
  3. Use an aluminum-based PCB board with 5oz copper thickness and 6 4*2 copper strips;
  4. Use 6AWG wire;
  5. Use aluminum alloy shell (under design);
  6. 3S-20S, MAX 200A!
    (In fact, all the components used have a withstand voltage of 100V (DC-DC, MOS, capacitors, current sampling chips, gate drivers), but for safety reasons, we use SMCJ85A TVS for protection.)
Motherboard functions:
  1. Built-in Bluetooth module (test completed);
  2. With AUX interface (test completed);
  3. With DC-DC controllable switch -Or shutdown(test completed);
  4. Equipped with BMI160 attitude sensor (interface reserved, testing in progress);
  5. Phase filter, current filter.
The motherboard has gone through many modifications during the design process. Below I share some photos of my motherboard (happy! This is my favorite part):
First version:
Second version:
Third version:
The fourth version (I haven’t gotten the board yet):
I’m ready to test the BMI160 attitude sensor!
Who knows what I’ve been through:
And the shell:
Tell me, what else do you want to know?
do u work for makerbase
Would you consider screw terminals for the leads, given how much of a pain it is to solder 6 AWG? Crimped wire termination to screw lugs would be much more achievable for attaching to the board, I’m not super knowledgeable about their vibration handling but it seems much easier
At peak power with <1% losses in the controller it’s still >150W to dissipate, have you done any thermal testing so far?
It’s great to see you guys sharing the design progress on this ESC. I also saw that Makerbase recently merged a bunch of hardware configs with Vedder’s main branch, which is very helpful.
So did you also design the 75100 and 75200 aluminum pcb versions too? Are you an independent designer or working directly for Makerbase? Did the 75100&75200 alu designs get sold to Flipsky? Did they make the 75300 on their own? Sorry for all the questions, but I’ve been working on the hardware configs for the 75100 and 75200 controllers for a while and haven’t been able to piece together the whole design origin story.
I’m excited to see a 20s phase shunt ESC finally be commercially available thanks to the INA241. Also with 3 temp sensors and phase filters! The thermals on the 75100/75200 alu are really good, some of the best in fact, so I’d imagine this will be a great performer.
A few questions/suggestions:
  • The DC-DC switch… so is this basically to shut off power to the STM32 and other chips so it can stay plugged into the battery without draining it? What’s the current draw with it on vs off at 20s? BTW for terminology you can use disable instead of disenable… or maybe just call it power on/power off if that’s it’s intended function? Or power on/sleep?
  • The 75200 alu (and it appears this design as well) doesn’t have ceramic dc link caps on the power stage - do you plan to add those here or did you find them not to be necessary?
  • How does the gate ringing look?
  • On the 75200, the decoupling capacitors near the STM32 were placed a bit too far away and it was potentially messing with the motor’s voltage and current readings. An example (the yellow and black lines). Might be worth reviewing on this design too?
  • How is the noise on the 5v and 3.3v rails?
  • From a mechanical attachment standpoint, the 75200 had added epoxy to the standoffs between the power and logic PCBs which is a decent idea… but maybe consider the ability to screw the logic board down? There is a lot of vibration, and it can sometimes be tricky for the fab to consistently solder those standoffs to the power board especially with 5oz copper and an aluminum backing. I have seen these fail by lifting off the power board on other ESCs. Might need thermal reliefs built into the traces as well.
  • +1 for posts instead of wires. 6AWG is very difficult to solder into the XT90 connector, and posts like the the MakerX G300 can make it easier to work with.
  • There has been a lot of progress on the VESC Express which is an ESP32 based bluetooth module, compared to the NRF52 based ones most are using. Not necessarily recommending that, but maybe look into it to see if it makes sense over the NRF52 which isn’t really being updated anymore.
I am very happy to receive such good suggestions, and I am also happy to discuss the development of VESC with everyone.
Regarding my identity, I am indeed an employee of Makerbase, but here I prefer to be an independent designer. As I said at the beginning, I will not attach additional links to the discussion in the future. Because this is not the job I should be doing.
The purpose of my coming to the forum is also very simple, which is to collect the functional requirements of VESC and the content that needs to be improved in the design. For example, the board I designed has functions that need to be improved. I will work on it in the next version or redesign it. I think this is What I should do as a designer.
I’ll answer other questions below:
  1. The shutdown function was actually implemented by Benjamin in VESC MK5. Its function is to turn off the power of the control end. For example, the 84200HP motherboard can be seen more intuitively (because the control board and driver board are separated). When it is turned off After controlling the power supply of the board, there is no power loop with the battery, and the theoretical consumption is 0 (currently I can only display values >10mA, and I have not observed the current);
  2. Ceramic capacitors are not unnecessary, but are limited by the structure, and our tests found that ceramic capacitors are more effective for small currents, while for large currents it mainly depends on electrolytic capacitors, and my design is more concerned with large currents;
  3. The 75200 line has been readjusted, and it is expected that the company will sell a new version in the next two days (of course, I am not sure about the time, because it has nothing to do with me);
  4. Regarding 5V and 3V3 noise, I will upload pictures of the oscilloscope after a while;
  5. Regarding the design of mechanical mechanism, I would like to have a more in-depth study with you, because this method is indeed unstable at present. Can you explain it in detail?
  6. Regarding the screw terminals, I have suggested it to the company before, but it was not accepted. The reason given is: the patch screw posts will produce a large force to pull the copper skin during the screw tightening process, which can easily cause copper skin. came off on the PCB.
  7. It will take me some time to understand the design requirements of the Bluetooth module.
Currently, the 84200HP has not been thermally tested, but the aluminum substrate selection was taken into consideration during the design. The current material selection is 2W/(m·k). Do you think it is necessary to use better materials?
Yes, I will not deny this issue. But please don’t ask me how to sell. I don’t think any company’s sales are linked to designers.
If you mind my identity, I will not attach any information about the company in the future.
i did not say it was an issue, but an employee of a company should always be upfront about it. its not hard to start ur thread like this:
hey people, im a hardware engineer for makerbase, and im currently testing new vesc motherboard…
This is really cool, thanks for sharing on this forum.
On the topic of ceramic capacitors, it is a good idea to add them close to the mosfets for high frequency content. Otherwise, the high frequency content can make its way back to the supply and cause oscillations and rf interference. Not good for remotes and Bluetooth, etc…
Will you be sharing the schematics? It would be really cool to have a detailed review here. I have noticed some of the low power stuff tends to audibly buzz (piezo effect) on some design, may be some opportunities to address this.
Why do the enclosures need to have cutouts for the caps instead of enclosing them entirely? And some mounting tabs on the heatsink would also be really useful
-z
Can you make the 3D files available? (At least the enclosure) I’d like to incorporate the controller into an escooter design
I’m glad to interest everyone. I have already shared the schematic diagram. However, there are still some things that need to be further improved, and I will continue to share the schematic after the modifications are made.
Of course, I will share it now.
MKSESC 84200HP Shell - Lower.STEP (604.7 KB)
MKSESC 84200HP Shell - Lower.STL (254.6 KB)
MKSESC 84200HP Shell - Upper.STEP (16.2 MB)
MKSESC 84200HP Shell - Upper.STL (2.6 MB)
do you have any info about 84100?
I really want to buy one
I have been looking at this 84200 on AliExpress, should I wait on this and get the 75200 or is this still an improvement even with the features that need to be corrected?
You dont have to do only soldering for the terminals. You can just bolt the terminals to the PCB from back side of the PCB and then terminals will touch pads mechanically. Then you can also user solder to increase conductivity…
What do you think ?
Also a waterproof VESC with at least 1kg aluminum block for easier cooling would be great like those kelly controllers.
it has REAL phase sensors etc, it’s definitely better.
yeah i would love to see and have a fully waterproof version with deeper fins/longer heatsink aswell as that would help alot in the scenario i want to use them in, it will make the case deeper but that’s not really a concern, so long as the length and width stay about the same it’s still very small
I think thats the biggest downfall of the Alu PCB series, the enclosure not being waterproof at all, and even if it was the connectors would get soaked
@Lucky
as for screw terminals, i suppose standoffs that accept 6mm or 8mm bullet connectors would be great too instead, like ones accepting XT150 or something? i mean those connectors are never gonna come out anyways unless you really want em to and pull on them
what happened to this controller ? i buy one from ali for my scooter. It seems to detect motor settings significantly better than my 75200. Estimated range much higher than usual, motor feels more quit and much more quick. But as soon as i pull full throttle and at around 190 amps/120 battery amps some mosfet blows up and shorts one of the phases.
Replaced said mosfet and another blew up instead. I eventually get replacement from ali seller and this one also blew up immediately in full thottle, but this time in some other way because it’s blinking red and i cannot find mosfet short.
Would have loved to have a working unit of it
Well my votol controller seems to have died, so I’m looking at this controller again, can anyone tell me the maximum safe battery amps?
I need to run 72v 100 amp battery bursts on my son’s dirt bike. Can this handle it?
Hello sir, can you tell me the 84200HP version you have on hand? Perhaps due to the lack of ceramic capacitors in the old version, it is more likely to generate spike voltage and cause MOS transistor breakdown when used at high voltage.
In subsequent versions, we have added ceramic capacitors.
