I’ve been feeling quite burnt out on the deck design since having to sand it back, so I decided to move onto other part’s of Nagini.
Firstly, I got my 3D printer back up and running by replacing the mainboard. This meant I could print the second 60T pulley:
Ignore the red 3D printed motor mount. It’s an older prototype from when I envisioned using my Globe deck and PU wheels, and had no idea what pulleys or belts I’d be using. I just figured I’d fit it to see where the main issues lie with the design before my next printed prototype. The end goal is to either waterjet cut the mounts or to CNC machine them, and hopefully anodise them afterwards.
I’ve also moved on to battery building. I ordered 50x Samsung 40T cells from Fogstar, which came a couple of days ago. After my whole fiasco around how to pay for them, I realised I had missed the PayPal option on the checkout screen…
I spent some time this evening measuring the voltages of each cell to ensure they are equal, attaching the insulator rings, and hot gluing them together.
I knew I wanted the pack to be completely flat as I am using a drop down deck, but I had no clue what orientations the P groups should be in. I laid them out on my board to figure things out:
And then produced the following, highly advanced, top of the range PowerPoint schematic:
To combat my burnout I figured more retail therapy should do the trick. I popped over to everybody’s favourite Chinese website, Aliexpress, and ordered some 70mm wide fish paper, some 0.12x8mm Nickel (reviews state that it is pure, however I will confirm upon receipt) and 50mm kapton tape.
Originally I was planning to rent or borrow a spot welder, but I caved in and bought this bad boy:
I’m hoping it will do the trick. It has a number of good reviews and although it is by no means a KWeld, it is spec’d to my needs.
While I was on Amazon I perpetuated my financial troubles further by ordering some ebony flavoured wood dye for the deck. The plan once my pyrography is complete, is to dye the entire rest of the deck outside the perimeter of the graphic, before coating with polyurethane and fine glass frit. I will test different timings for when to add the frit to the PU to ensure it provides good grip without sinking beneath the coating, yet is unable to fall off.
