12:45 You changed speed from 37 to 40 and then applied it
It applied just fine. You probably did not test throttle.
12:59 Your board shut down because of built-in timer switch
This is when bad things happened. When you powered board on, motor configuration was destroyed. I don’t know if it was destroyed when shutdown or power on, somewhere there. Not only motor direction setting, for example hall sensor values also were reset
Most likely not actually! Changed setting, talked to a friend for a while, turned it back on (after auto shut down of DBMS) and only then I noticed the problem!
Had no idea that this could happen during shutting down, or booting!
Anyhow, muchas gracias for the investigation
I’ll keep an eye on it.
this is a known issue on the unity, my board has done this a few times in the past and as far as i know there is not any fix for it. as @rpasichnyk says it seems to happen randomly when the power shuts down.
my best advice to avoid getting caught out in the future is to make a full settings backup in metr. if this ever happens again you can just load the backup and write it to the board.
This has saved me from getting stranded a few times before.
@rpasichnyk you have seemed to be pretty open to metr feature add-ons…
I don’t know how easy this would be, but I think a cool stat to add would be average voltage sag/battery amp, or avg V sag/10 amps of load.
How I think this would possibly be implemented is by taking the average voltage over the last few seconds that last saw 0 battery amps as the baseline, subtract the current voltage from the last measured baseline voltage divided by the current battery amp draw… or something along those lines, I think the only real useful values would be max voltage sag, and overall average voltage sag per battery amp drawn. Just some ideas.
We have the data to say definitively how much we each sag, and it seems like a fairly linear relationship at least from my data… it would be awesome if people could just say on average I sag 1.2V per 10 amps or 5.5V per 100A with such and such configuration rather than guessing off a few days points or just feeling it out kinda.
Had an HFI hiccup at the start, the pause in the middle was where I jumped off after hitting gravel trying to avoid a pedestrian and his dog. Didn’t fall, just ran it off.
Had two reported BT disconnects, but seemingly this didn’t affect recording.
Just wondering about the HFI setup though, I don’t see where you toggle it on / off?
