Here:
The first “Sensor Mode” is for BLDC
@rpasichnyk what kind of range is reasonable in the metro pro i get a lot of disconnections with phone in my pocket during rides and with board on charge with my phone on the sofa 5m away
My other metro pro with small antenna works at the other end of the garden fine 30m away no disconnections.
Take a look at this.
i use the non antenna version. Haven’t tested it above 10-15meters but even they were solid.
What kind of enclosure do you use?
Just a quick question: When I do ‘Save configuration’ in the expert tab. Is it the configuration of both Vesc and DBMS?
Fiber glass encloser on a spud deck so only thing that could be affecting it I’d the position on the unity but that is a fixed position
Can you take a picture how it is positioned? So the one you are talking about is a Metr Pro UNITY and the other one is a standard Metr Pro with small external antenna?
Bluetooth spec says 33ft minimum supported distance and personally never had an issue connecting throughout my apartment to bluetooth things (there are some dead zones behind certain walls or big appliances), but like others are saying this seems unexpected to say the least. Would verify you have a solid connection between the module and the vesc, could maybe reinforce with some sort of hot-glue or silicone. Something you can glob onto the connector to make sure it’s not shaking loose or something similar… it seems unlikley, now that I’m writing it too but just not sure what else to try… does it disconnect only when riding or also when walking say 20ft away with clear line of sight?
To everyone that ordered a Metr Pro module in the last couple of days or who is planning to order a module in the near future, please notice that there could be COVID-19 based shipping delays depending on your country. At the moment Deutsche Post (local shipping company) will not deliver goods for an example to the US or Canada because of COVID-19.
We try to ship orders from Sweden but regulations can change every day at the moment so please keep in mind that there could be some unforeseen delays when you are ordering now.
Sorry for the inconvenience.
Disconnects hanging on the wall charging not moving phone siting on the sofa arm less than 5m away full line of sight. rules out vibration
yo what’s that thing with the lit screen
BMS screen
i wonder if the backlight generates a problematic amount of radio frequency interference
Think it’s one of those 0.96" OLED displays can get for a few bucks but doesn’t hurt generally to start disonnecting things one by one or start with it stripped to bare minumum connections (but probably not a whole lot of optional connections). Anything weird in the data if recording during disconnects @Darkie02?
To point above about FW version I haven’t upgraded to 5 yet so that could be a culprit.
Strangely no it records past the disconnections just my phone keeps vibrating with disconnection push notifications
The screen was disconnected after set up and the battery has sins been heat shrinked after that photo.
Any way of the metro pro reporting it’s signel quality and strength.
The PPM remote receiver is down the side of the ESC but there’s not really any we’re else to move it to. The batty has very long + leads on it that run from the middle to the frount of the deck AS90 then to the ESC at the back - can’t be more than 15cm must almost good 1m of AWG10 cable from the cell in total
Would be really interesting to see if external antenna helps in your case
Sure, only now it keeps recording despite the disconnect notifications. What do the logs say that I sent?
I did some testing with my connection. I continuously get disconnects with (I presume) data loss and sometimes the app freezes because of it. But this only happes when I hold my phone vertically (pocket). When I hold it horizontally (parallel with board) I never get disconnects.
Is there something I can do to improve connection. Soft- or hardware wise?
I also notice that, on the webshop, there is a unity module with antenna available, didn’t notice this before? Can I still connect an antenna myself?
It keeps recording because metr app reconnects after disconnections. Sometimes even a good connection can be interrupted by strong interference, no reason to stop record because of that. Logs say “disconnected”, most likely because weak
