meepo site
Question is if they thought about larger bearings
Maybeā¦either way the axle remains the same
8mm axles donāt belong on premium boards that go over 30mph
Coughs in Hoyt EL2
checkmate! ![]()
Lol, touche, if looks were speed that thing would go 50mph
Please tell Hoyt to add what battery will fit in their DIY deck offerings. The price is a bit outside my budget, but those things are
As soon as I get there I will! Iām still in NJ packing and still havenāt been fully briefed on everything.
But Iāll be happy to answer a ton of questions when I get the keys to the shop lol
Awesome. Excited for you!
Hi frame,
thanks for all your info. Just did basically the same thing you did, ordered the Zeus baseplates for my Meepo Hurricane. Wondering how a) you like the setup and b) is using the original Hurricane motormount fine, in terms of clearance? Your picture suggests soā¦
Thx
TKP is pretty decent, way better than DKP imo
yes, u can use the original hurrican motor mount, thatās what im using also. if u fear about clearance, u can also get a longer mount from @IDEA or @Tony_Stark, both are top notch stuff
Pretty decent, ok, Iāll take that for now :). Did you change bushings after you switched to the Zeus baseplates? I donāt fear clearance issues, if you are fine with it, I should be too. Do I need any other parts, when receiving the Zeus baseplates, for the change? Thanks for your input in this thread, really appreciate the āsimpleā solution to get rid of the DKP setup. Canāt wait to ride the hybrid
Yeah, gave up on DKP. ![]()
riptide all the way baby, the only issue with bushing is that u canāt use barrel cup washer on the roadside bushing, it has to be either flat washer for barrel or small cup for cone
sketchy af
Alright, so whats your exact bushing setup for the Hurricane, if you donāt mind me asking (and your weight, if that doesnāt get all tooooo personal haha)? I guess the Riptide Hurrricane Kit doesnāt make sense any longer, now that it is running with TKP. Just trying to find a good benchmark here
krank canon 96a rear, cup washer board side and flat washer road side. 93a on the front, same washer setup.
if u want to know more about riptide bushing setup, @RipTideSports has a great thread for it: Bushing and Truck Setup Help Offered
65 to 70kg depends on weather and gear
Thanks, so basically a rather stiff setup for your weight, something that I am also tending towards (being 80kg myself), as I am generally riding at higher speeds. Thanks for the riptide thread, will try to work my way through
You can also just post your setup and ask Brad for his thoughts. Heās kind of amazing with his customers.
