LLT SmartBMS questions
I suggest u check p5, 11,14 and 15. It’s not normal when bms reporting them higher than rest, but it goes back down that fastand in line with the rest when charger is off
Hmm I ran the pack down to 25% but llt still reports 100%.
I manually set my voltage percentages and that fixed the 100% charge always showing
If your BMS isn’t wired into the discharge the reported percentage will almost always be incorrect unless charging, at least in my experience with a half dozen LLTs
lil cross linking
Troubleshooting “fluctuating balance readings”
:heavy_multiplication_x: reference
:skateboard:
:skateboard:
LLT (JBD) appear to sell different BMS for LifePo4 vs Lion.
do you think these are the same hardware with differnt software configs? Could I reconfigure a LION BMS I have for LIfePo4 ?
I find making a ‘dummy’ change, eg turn balance while charging only on, then off again updates the static battery percentage to the correct value. But it doesn’t update after, so becomes wrong again .Wondering if it’s limitation of the app?
Yes. U do it in the app
Does this BMS , specifically this one has some sort of on/off button / circuit ? Or is it always on connected to the battery.
Do I need to control on it via dedicated button on my enclosure or I can be satisfied with my VESC on/off switch and that’s it ?
It’s always on & transmitting bluetooth signal.
Doesn’t this kill the battery ?
No.
And you wouldn’t want your board set up to discharge through the bms anyway.
Relying on the vesc switch is safer than using a switching bms.
If you must discharge through the bms, you’ll likely want one rated to a lot higher discharge current than you linked.
Most of the JBD bms have an e-switch where you can turn discharge on or off through a button on the app. A lot of them used to have a physical switch capability, i’m unsure if that’s still the case.
yes over a very long period of time. Depending on size of battery. 6 months to 2 years kinda time. Some versions may do better. But if storing a small battery for a long time. Best to check on it. Better to use it and not store it.
So I’m unable to turn my discharge onf, using a combined port llt.
Discharge is on when charging though, it’s hooked up to a light.
Any idea how I should fix it? It worked last week.
Edit: fixed it’s self in a day idk how
Did anybody try this BMS? https://www.aliexpress.com/item/1005006347440227.html?fbclid=IwY2xjawEZyHNleHRuA2FlbQIxMAABHVpAfuZmA5m6I3IbITgh6r2YExkehx5dBaMP_NGSt1zONRTjpHJ4OtW9Ww_aem_Qhx5B8bwTgJk8jdXjy6DzQ
Yes, lots of people running these JBD BMS’ (myself included). Built in Bluetooth and smaller footprint makes them the preferred option.
Actually ordered one of these for the size as my big one (also JBD) was at risk not fitting. It was even smaller than I expected. BT built in which means I can probably connect the UART elsewhere. Happily surprised it was even smaller than I thought.
But I haven’t been able to test it yet. I trust it as long as it’s from the same brand (JBD) as people have been using for years.
