I’m able to pull current out through the charge port. (it shows up as discharge in the app) so I don’t think there’s a diode. and think P- and C- are connected on the board.
Charging is turned on, yea
how to calibrate voltages.
I’ve found it at least clears them each time you write the config.
I don’t get what this LLT in my LaCroix is doing…
It says it’s at 100% but 18s pack is only at 73V.
FreeSk8 reports 73.3V as 86%.
The LLT seems to be toggling charging on and off every 5 seconds because when charging is on at least one cell quickly goes above 4.25V:
Is this pack OK? Does it just need to stay plugged in an balance for a while?
The LLT does seem to be balancing for about three seconds before it kills charging for another five seconds.
Why is your cell 15 at 4.3v?
Thats the reason the bms is not charging
very much not ok, u got pgroup at 4.07 and 4.32, that’s a huge difference and bms has to work very hard to try and balance it out. if u keep charger plug in it will probably take weeks to get all pgroup to 4.2
Yeah it’s wierd the cell that is high jumps about tho it’s not always that one.
Hmm I let it go for a few hours and eventually the charger clicked off and the batteries look balanced:
…at 4.1V per cell… still only a level FreeSk8 calls 94%
It seems like when it’s charging the cell voltages bounce around which cause the BMS pvervolt to trigger every few seconds but then once the charger cuts the juice all 18 settle at the same level.
I suggest u check p5, 11,14 and 15. It’s not normal when bms reporting them higher than rest, but it goes back down that fastand in line with the rest when charger is off
I manually set my voltage percentages and that fixed the 100% charge always showing
If your BMS isn’t wired into the discharge the reported percentage will almost always be incorrect unless charging, at least in my experience with a half dozen LLTs
lil cross linking
Troubleshooting “fluctuating balance readings”
reference
LLT (JDB) appear to sell different BMS for LifePo4 vs Lion.
do you think these are the same hardware with differnt software configs? Could I reconfigure a LION BMS I have for LIfePo4 ?
I find making a ‘dummy’ change, eg turn balance while charging only on, then off again updates the static battery percentage to the correct value. But it doesn’t update after, so becomes wrong again .Wondering if it’s limitation of the app?
Yes. U do it in the app
