I’m thinking of cutting a piece of aluminum that fits snug in there, and have the set screw press into that. And then fill the gap with JB weld
If you ruin your hanger adapters in that process I got a couple extra you can take
The red aluminum part you mean?
Been awhile. Was busy with life and fixing a few of my friend’s boards.
I got Riptide bushings in 80 and 85A, popped the hammocks on them. I’m gonna get to painting the deck and put them together this week
That drivetrain looks so nice, are you sure that’s gonna be stable with such a low duro?
Yep, i ran the same bushing combo on this build, and have gone 60km/h on it. Split angles are great.
Hey man, thought I’d let you know I developed cracks in 2 sets of those motor plates. Material is too thin there. I ended up getting some thicker aluminum with just the holes I needed. If you want a DXF let me know.
I’ll post an update soon
Better yet, machine a pair for me!
I could forward you a pair from Sendcutsend or Oshcut. But I’d assume there must be similar laser cut services available there no? I paid about $32usd for the pair shipped to me.
This was what I sent them, which was a pretty exact fit. They don’t countersink so you’d have to add that yourself.
That works too.
How much thicker is this? With the extra thickness, the mating points of the gears would have to be taken into account too?
Then did transparent blue and yellow over, which gave me this foresty green. Nice. I’m thinking of leaving the sides and bottom metallic gray, just because.
I can’t stop looking at it.
On goes my logo, and a subtle black line where the silver meets the green. Clear coat goes on next. Then I’ll bring it home and hopefully put it together for a maiden ride
HAY. Where you get them spiral bevels? Gimme.
I found it in the last level basement of @jeffwuneo’s 20 stage boss factory, right next to the Jedboard AWD. I knew what I had to pick
Bro this paint is amazing
text summary to get my brain around it, please?
Prime
Silver
Metallic gray
Blue
Yellow
What makes the paint texture, just from multiple light mist coats?
Did you bedliner some other decks before paint?
Yep, that’s right.
The paint texture on top is truck bedliner, i’ve been using that as my ‘grip’ for all of my builds. No more griptape for me!
So you bedliner it before the (first) silver?
