This will be a bit more than a standard build log. It follows me from my noob beginning of not knowing shit, and hopefully ends with a properly built board and me being a half decent builder/assembler.
I came into this community about July 2020 with much different goals than what ended up being quite the learning excursion. I ordered a BKB Tayto kit in July with the intent to assemble it and ride as is. Then research happened and I switched plans to do a deck swap to a Moonshine Sidekick right away when I received the kit.
The BKB kit was taking quite some time to ship, so while reading on here and seeing all the shinnies, I decided to do a full fledge build with the Moonshine. It was my ideal lightweight kicktailed board: mallgrabable, agile, yet long enough to spread the legs and get up to some decent speeds.
What I imagined went into a build differed far from reality. I thought I could order parts that were all plug and play and I could get away without even learning how to solder. Oh how wrong I was, sweet summer child.
I came into this with almost no skills that applied to building electric murder boards. The only thing I had going for me was my ability to use tools quite precisely, good problem solving skills, and a keen eye for detail. Most of which which came from my background in high end construction.
So I really need to thank this community, y’all are rockstars! There is no way I could have pulled this off if I was only learning from reddit/Facebook. The openness of folks here to share knowledge is really admirable, and makes everyone better because of it. From all the tutorials/wikis to the kind folks in the noob thread answering questions (I still learn from there even if I don’t ask Q’s) to the very helpful knife gang that is fresk8. Thank you all(!)(except @BillGordon , you’re a pussy
), I’ve learned something from way too many people here to start naming everyone off, basically if you contribute knowledge here, I’ve probably learned from you. Building and learning new things is very therapeutic to me and the pride of riding YOUR own board is very much rewarding.
So enough with the chatty sappy shit, lets get to the goods. Don’t get your hopes up too high, most stuff will be pretty rudimentary to y’all, but felt like a solid achievement for myself.
The Goods
Moonshine Sidekick 35"
Eboosted SS Enclosure by @eBoosted
12s3p Molicel P42a by @A13XR3
Stormcore 60D+ by @Deodand and Co
Boardnamics M1 Thane Drives by @Boardnamics
184mm BN Hangers from @KaramQ
Paris V3 Baseplates 43/50 split
Hyperdrive 100mm Wheels
Riptide Bushings/Pivot Cups/Tunnel Risers by @RipTideSports
FlexiBmsLite by @SimosMCmuffin
FreeSk8 Robogotchi GPS Logger by @DerelictRobot @skate420
6355 190kv Maytech Motors
BnS Guards/Tailpuck/Panel Mount by @poastoast
Hoyt Puck by @JJHoyt
