IDEA - Deck with Brackets
IDEA Split Angle Brackets Group Buy
I would like to add that if someone orders a set of brackets, he will receive an additional discount on the deck.
Standard price is $180, currently I have a price reduction to $160 but if you buy the brackets the price for the deck will be $140.
Deck with RKP trucks.
Glass bead blasted aluminum.
63xx motor mount with clamps for 22 x 22mm hangers, also available for Matrix 2, Matrix 3, Trampa ATB and IDEA Double Delta
Another 2 types of motor mounts,
From the left 60-68, 60-72, the thickness of the motor plate 8 mm.
In the photo on the right 72-82, motor plate thickness 10 mm
The next type of motor mount, adjustment range 60-72mm
Options of available clamps:
  • IDEA RKP (20x20)
  • IDEA DPKP (20x20)
  • IDEA TKP (20x20)
  • Boardnamics 220, 270mm
  • Torque 220 CNC
  • Trampa 12 Fifties
  • Trampa ATB: (19.5×19.5)
  • 3dservisas FatBoy Solid (19,70 x 18,10)
  • 3dservisas FatBoy Finality Channel (20x20)
  • Surf-Rodz 200 RKP
  • Newbee Triplelinks (22x22, 6mm Chamfer)
2 color set of DPKP (Double Delta) trucks.
Trucks and base plate in champagne color, brackets black
@IDEA what do each of these mounts weigh including the mounting adapter?
V11 for MBs m2 and m3
The weight of one motor mount is approximately 185 grams, so 2 will weigh 370. Matrix 3 and Matrix 2 clamps weigh similarly, The difference is about 8-10 grams, if you need the exact value, let me know
Double Delta 300 and 270 trucks with ABEC 107 wheels installed
RKP 300/270 trucks with BOA 100 wheels installed
Will these adjustable baseplates work with the idea hangers?
They should fit with no problem. The idea hangars mount onto the surf rodz bushing seat (which can be used with fixed or adjustable baseplates).
I am currently planning a build with these adjustable baseplates along with idea hangars. I can send photos when everything arrives.
Yes please!
@andoug was first, I wanted to say the same thing :slight_smile:
My hangers are not much different from the original ones, but the number of variants is larger, you can choose from 150, 180, 220, 260 mm
These are widths without axles… the number of axle lengths is also large:
You can choose from: 42, 52, 62, 72, 82. The thread is 15mm long
There is another type of hanger without axles, i.e. 180 mm for hub motors
TKP hangers with Evolve pattern clamps.
You can install Chinese Omni gear drives, I think Linnpower should also fit
I will also check the possibility of installing the Omni gear drive on DoubleDelta and RKP trucks
Soon, the NewBee gear drive will also be tested on Double Delta trucks
The same drive mounted on RKP 270mm
This looks so good as a urethane build
Double Delta trucks, 270 rear, 320 front
@fujio001
@IDEA
Thanks Tom, everything arrived quickly. Parts are so well made :ok_hand:t2:
