Please be compatible with Apex Airs… ![]()
These are short motor mounts for Street and AT boards
But very similar only slightly bigger I will also design for APEX, Trampa, MBS and IDEA Double Delta
trucks, so that chain transmission can also be used ![]()
However, if you wanted these short mounts for the Apex Air, I would have to check if the hanger would fit in the mounting hole
IDEA RKP (20x20)
IDEA DPKP (20x20)
IDEA TKP (20x20)
Boardnamics 220, 270mm
Torque 220 CNC
Trampa 12 Fifties
Trampa ATB: (19.5×19.5)
3dservisas FatBoy Solid (19,70 x 18,10)
3dservisas FatBoy Finality Channel (20x20)
DKP (Evolve Mounting Pattern)
Surf Rodz HEX TKP
Surf-Rodz
If you have any other ideas, let me know
you mean untill the sleaves crumble from beein near air.
Another type of motor mounts, slightly reinforced, motor plate thickness is 10mm, made of 7075 alloy.
Adjustment range 72-82
Fits MBS Matrix II, Matrix III, Trampa ATB, Apex AIR, IDEA DPKP, RKP, TKP.
Will be available in the online store tomorrow
From the left motor plate with a thickness of 10mm from the right 8mm
Seems like they would work for really small wheel pulleys only?
I mount the 15/72t gear ratio without any problems
Use this calculator to check pulley sizes and belt lengths
Theoretically, you can even install 15/80t pulleys
New TKP hangers
TKP hangers fit Surf-Rodz TKP base plates and Surf-Rodz TKP bushing kit.
An innovative solution is the possibility to invert the hanger, and thanks to the asymmetrical shape, the clearance under the board changes by 7.5 mm.
The hanger is available in 2 variants:
- width 180 mm
- width 150 mm
The ends of the hangers have a profile of 20x20mm so you can mount the motor mounts but you need to replace the axles with longer ones.
You can also mount Linnpower gear drive, etc., because I have clamping rings with 3 holes (Evolve pattern)
A board without electricity ![]()
Currently hangers can be bought 15% cheaper because I am extending the sale until the end of November
how much would it cost for two 20x20 adapters out of curiosity (potential future purchase)?
Do you mean clamps for motor mounts or gear drive?
One clamping ring costs $10
The shipping cost depends on where the package is sent and the size of the package, do you need anything else or just the clamp rings?
oh nice, that’s less than i expected. ill probably grab a couple mid december
New boards in the gallery… if anyone would like to share with me pictures of their board built with my parts it would be great… ![]()
