IDEA - Deck with Brackets
Are those the 220 or 260?
Also, how are the adjustable plates? All the ones ive tried from SR have been questionable at best haha.
260mm. I haven’t messed around with the SR adjustables yet. Adjustable from 0 to 60
Split angle brackets by design @Ac53n
I will add the brackets on my site after @Ac53n tests them.
I made the brackets according to @Ac53n’s design
Thinking of making them a bit shorter and thinner with the ends ending my style ie as in the horizontal brackets with a depth of 30 mm
So I think in April or May there should be 2 versions to choose from.
Hi Tom - how is the turning circle on your new Double Delta trucks? Anyone done any video reviews or such to show?
The turning radius depends on the bushing used, and the deck, (angle of inclination), so there is no clear answer… :slight_smile:
I will check in my board and write you Tomorrow
I don’t know, I haven’t seen it, but I think there will be 1 or 2 boards with Double Delta trucks at ESK8CON, so you will be able to see them at the races :checkered_flag:
432345067_799501018753198_3430163054439204945_n (1)_cr
I have added some videos on YT but they are not reviews
2 colored RKP trucks
i was going to wait until i had time to throw everything on and mock my whole board up and take some proper photos but this is way too clean not to post teasers of now lol.
The only good use for a yoga mat :grin:
Inward motor mounting is :fire:
Enough clearance for that?
What’s the total length of the assembly btw?
Daaaaammnn. Looking good!
I should be able to juuust barely clear a set of reacher 6455 motors inboard mounted.
Not sure off the top of my head on overall length. Probably right about 40" from tip to tail? The deck itself is about 27". Current pics are with the brackets on the shortest setting, i can get another 60mm of total wheelbase length if i want by changing the mounting holes used.
The length of the set can be changed because there are 3 rows of adjustment holes in each bracket
BTW
This is a slightly shorter 2nd version of the brackets based on the idea by @Ac53n
Some interesting photos and information about building a board with RKP trucks :slight_smile:
Here are photos of another board with 4GS drives and Double Delta trucks (DPKP)
@IDEA
What are the deepest drop brackets you have Tom?
I think its his type four brackets at 30mm of effective drop for conventional brackets, or the one off split angle brackets i had made at 35mm of effective drop. If you need a crazy amount, i do have the files for an insane 70mm drop set and a set of steel prototype brackets.
45 mm, but the most commonly ordered ones are 30 mm deep.
If you would like 45mm give a nac… standard are very long because they were designed for this board
but I can shorten them a bit :slight_smile:
I think 45 will be perfect for what I want!
How many monies shipped to Aus?
Time for the next midlife crisis I guess :stuck_out_tongue_winking_eye:
New brackets with positive and negative 10 degree inclination
