Yeah that’s 84.6 wh/mi. Impressive right. That’s more than @Trampa said was even possible on a board.
I’m running maytech 63100 on 5:1 gear drive with 8" tyres. Also max motor current in this log is only 65A per motor which suggests that I had my board in its low power profile for this ride
and I managed 50wh/km too so 80wh/mi on 8inch tyres and 1:5 gearing. We ride our boards hard enough off road and record every ride for analysis. Can you imagine that 48G pack on 1:6 gearing? would be absolutely awful
I’ve ditched that cell idea long time ago. Will be using p42 molicell pack that you guys will make for me I’m just trying to figure out my range with that pack.
4A continuous is a great operation level for the 48G. Other cells can run at slightly higher voltage levels and for a bit longer though.
Average and true continuous current draw can be two very, very different things though!
Pulsing a 48G to 16A will result in huge voltage sag versus other better performing cells. Depending on the charge level and your BMS settings that sag could result in the BMS throttling down or other unwanted actions.
Does this make a 48G pack useless? No.
It’s just that there are better cell choices IMO if considering what to use (or buy) for a new pack.
I am pretty sure anybody reading this thread don’t need Trampa to admit being wrong to get to the same decision as you.
People like Lee, Q and Mooch are testing stuff and providing good advice for those of us who can’t afford making mistake on expensive and potentially dangerous gear such as batteries. Thanks for looking out for us guys.
How do we calculate true continuous? I can get XML data for that log and would be curious to smash out a script that can calculate these sorts of numbers if there’s a simple way to calculate
You might be able to calculate the average over a time period but that average number wouldn’t be the same as operating at the same level continuously.
Let’s compare 4A true continuous versus 16A pulsed at a 25% duty cycle. Both of those take the same amount of charge out of the cells when averaged over time but the 16A pulses result in a lot more voltage sag (when being pulsed) and will result in throttling down of the power or other bad things earlier than if operating at a true 4A continuous discharge level.
You could have a wide range of pulse current levels and duty cycles, all averaging out to 4A, but each would result in a different total ride time due to the different levels of voltage sag during the pulses.
You might be able to set the BMS to ignore the sag, by using longer time settings for when the BMS reacts to a low cell/pack voltage, but that isn’t a feature on all BMS’.
Especially if you can push assist from time to time
I remember the good old days on a boosted…
Never thought I could get 16km range out of the 99Wh battery pack
Where do you get such info from? You can even waste 100Wh/km if you like. Question is: is that desirable? In the end we want to build efficient boards that consume 25 to 35 Wh/km.
Consumption also depends on rider, ride style, terrain, weather, gearing wheel size etc.
Luckily we can easily build different boards with different cells and different gearing and then see how it all impacts the efficiency. There was a reason why Benjamin coded the software in a way to show you all the stats.
If you would tweak all parameters on your board and would use a bigger pack, the cells would see even less strain, probably below 10A peak and about 3A average.
