But it’s the software in combo with the HW…
Not only unity
The issue does not happen on UnityFW
It does not happen on Vesc fw 4
It does not happen on Vesc fw 3.66
It does not happen on Vesc fw 3.65
It does not happen on Vesc fw 3.61
It does not happen on Vesc fw 3.103
It does happen on vesc fw 5.01
It does happen on vesc fw 5.02
It does happen on vesc fw 5.03
on 4 different motors
3 different vescs (i can test a 4th one if you want)
and on 2 different remotes.
I’m not sure how i can use this to fix my issue.
Did you only test it on the bench? It is a current controller and you need load.
Yes, as i’m not really comfortable running a setting that could launch me at full speed.
Did you watch the video?
To dig down to that it would be good to spin one wheel only with the standard detection.
Do you mean this as standard detection?
setup motor FOC, load default setting, run detection. Then do not change anything.
Then use keyboard keys to spin up the motor.
these are wrong again.
Activated the keyboard and used the current control
smooth without problem. Nothing else is touched, no input was configured or anything else. Duty cycle current limit start is at 1.00 as it’s the stock setting.
And if you now set it to 0.85?
same thing.
Smooth without the crackling.
If i were to use the remote it would come back
Try it.
at 0.85 and a remote it’s back
spikes are when the issue appears
now setting it back up to 1. (duty cycle is still at 0.95)
and it’s as smooth as it is with the keyboard control
Can you cheat the input wizard for me, so that 90% throttle is 100% throttle?
same result.
issue at 0.85 and no issue at 1
Full throttle on the trigger was set to 90%
Just to clarify 100% on the trigger should be 90% in the vesc tool or 90% trigger should be 100% on the vesc tool?
Edit: same result.
Now i’ve tried 100% throttle translating to 90% signal and 90% throttle translating to 100% signal.
Do you have another remote?
i do.
Nano, mini and vx1
The result above is with the mini
The issue also appeared with the vx1 (though with that i haven’t manipulated the throttle on the wizard) Just the regular input wizard.
Could be HW related. Keyboard works, but not PPM input doesn’t…
I’m not familiar with the third party ESCs. I can ask Vedder where the problem could be.
