Go-FOC D100 / D75 / D60
100a motor current each side
Both actually, but your xt90 won’t like that. 100 motor ps and 60 battery amps per side is probably what you would want at most
For the build I’m thinking of I’ll likely go AS150, which I’ve done in a couple others.
It wouldn’t be at peak for very long, and the XT90 is okay up to some really high currents if it’s not for longer than a few seconds.
Same here! Recently connected DV6 Pro for the first time, only one side blue led lit. Other side is dead , will not connect to vesc tool with no visible problem. Emails sent and no reply
Usually the light is off due to the internal breakdown of the MCU. For example, a pin of the plug-in is short-circuited to a high voltage (greater than 3.3v), which will cause the MCU to break down.
Are you saying a pin in jst connector could have shorted to 5 volts or higher? I will check all plugs when I get a chance this weekend.
I just got my D60
Will my ESC explode or not? I think not, since the firmware looks to be correct.
@YUTW123
I’ve set up a fair few d75 and d100 now and none of them have blown up. Some of them have refused to detect sensors consistently but no sparky booms.
Been an hour. Your stuff didn’t burn down right? :upside_down_face:
Not yet
So I just got one, plugged it in and it doesn’t turn on…
Waiting on a reply in email now.
Kind of need a little more info than that
Have you done anything to troubleshoot it yet
did you use the included power button?
Yes
Tested it on multiple batteries including a 3s and 12s, also tried without power button
@YUTW123 What testing is done on these before they leave the factory? What’s your QC/QA methodology?
Short press for 1 second to open, tap to close. Automatic shutdown after 10 minutes of inactivity
Edited: Turning it on the first time required the power switch.
Can we change this?
