Woohooo! This is awesome! Of course people will wish it went even higher voltage but you’ve got quite the awesome product here. Will be cool to see how this goes
I’ve wanted to make a HV swappable pack for my MTB for a little bit now, this would be great ESC to throw in there.
Oh and to add to this, would you be willing to share some of the testing with us? I’m sure many would like to hear how it was tested
snagged!
i see the esc include an on/off switch, is it a pre charged anti spark?
interesting product for sure!
The internal electronic switch only turns off the power of the logic part, similar to the HD60 and HD75 solutions
So it is essentially a sleep mode? “Low power state” or something
wow, in that case, do u have roll to start function?
The entire system except the MOS part has been shut down. Basically no quiescent current,,,
No slide-to-boot feature… ![]()
At 113 x 66 x 23.5mm, it’s only a little bit bigger than the DV6 (at 106 x 71 x 23mm) and even then only really in one dimension. That’s a very neat little unit.
nice, no idle drain is still pretty good as long as the AS doesn’t fail
This looks cool ![]()
let’s try it
Ive had phenomenal experiences with the DV4 and the DV6, so I’m hoping this one doesnt let me down like the ubox has. Super excited!
If anyone is upgrading to the D75 from the DV4 I want your DV4
Damn, next VESC purchase for sure! I’ve been loving the DV6 Pro and now with this I have an affordable way to go for 16s
How about a DV6?
I’ll have to check if it fits, DV4 is gonna be perfect though, its a Meepo V3 enclosure
wheres your button going
Same as the stock button, if its a mom ill splice it into the DV port or ill buy a 10mm latch
dv4 doesnt have an antispark D:
there is no button
unless you can shove one in
Ah damn, I’ll use the tiny FS one then
A Unity is so close to fitting but not quite
