It would be awesome to have this cleared up once and for all, because I distinctly remember you mentioning that it works best on HW with adjustable filtering, but it can still be used in any other VESC based ESC.
HFI can work on any VESC based ESC and some people report great success. If VSS is an evolution of that (with an initial bleep and then some extra magic), is it absolutely required to have SW adjustable filters or can it be used regardless? Is it tunable by the user in any way or form? What’s the word on temp sensors, again are they required or recommended?
Please clarify this for us, lots of people have been asking for months. FW 5.03 is a great update and from my point of view and it is worth it even if you can’t use VSS (for the detection improvements and UI alone!), but for all that is holy, it would be a lot easier to get people hyped and excited about it if this information was easily and widely available.
Needs adjustable filters to work as intentioned, temperature needs to be measured and compensated, usually no need to tune it, but there are some parameters to play around with.
VSS can determine the rotor position at at 0RPM. From there it can generate high torque and keep track of the slow spinning rotor. And there is no noise.
HFI is also very good, but not as good as VSS + you have the noise.
However, the new Tool has so much cool stuff and detects motors so much more reliable. VSS is just on of many things that are improved. Jeffrey worked a lot on the UI for example, then we have motor/ system efficiency plotting, scripting, better wizards and all the stuff you can find in the change log.
I’m posting here because 3.01 is the only difference I can think of to cause this.
So last night I was poking around the new VT and looking at some RT data and graphs from my board. Had my DV6+ on 5.2 connected through TCP using a metr.unity to the full APK on a Chromebook in limited mode.
The only things I changed were the VESC numbers (86 to 0 and 65 to 1).
Rushing out the door to work this morning and I discover I lost all ability to brake, I only feel a slight braking stutter at maximum brake. Throttle behaves perfectly normally.
Tried calibrating PPM and that didn’t change anything.
No HW changes and no other SW changes so I can only assume this is something to do with using 5.2 in 3.01
EDIT: so I was at work, stuck with a board that had no brakes and nothing to use VESCtool on as the board is sealed with metr inside and all I had was my phone. I managed to just poke around in the expert part of metr enough to get my brakes working again by setting up the motors with manual values and re-detecting HALL sensors.
thank you community for being the reason I even knew how to do all that.
Did they fix the issue where it’s impossible to find the custom file on your phone? I remember downloading custom files and put in them in my download folder and then when I go to the download folder from the vesc tool app it won’t appear.
If you want a simple way, go download the VESC 3.00 tool from the precompiled VESC tool archive. It will load 5.2 for you.
If you want to use android and manually load 5.2, then go back in history on the github and you can see it. Open the folder with the same name as your current firmware’s hardware name. Here is the 5.2 github link
It is generally not recommended to change settings using a vesc tool version not meant for that firmware. It might be fine, but it might not be. I suggest you go back to vesc tool 3.00 and re-setup your board. You can then save a backup of the settings as an xml file you can later apply if you are messing around.
You know what’s weird? It worked fine in the beta versions, but doesn’t seem to work in the final release. You can uninstall and try to load this one (latest 2022-01-12 beta apk):
