I have some flats kicking around. I’ll look when I get home.
My other 3 200x75 tires showed up too. Can’t wait to dick around with them.
appreciate it brother!
Mentioned bi-metallic corrosion where aluminum interfaces with steel on the Carvons, @b264 asked if I could post sime pix… Here ya go…
Just pressed the motor off the hanger:
Close-up:
Both the above are untreated… Both pix below are from the opposite axle where I’ve already cleaned the corrosion off a bit with Scotchbrite and WD40
Heavy deposits to light galling and pitting… I hope this is what you wanted Brian.
Discuss
Wow, thank you very much
Howabout silicone nitride? Better than ceramics for reliability? Yet better than steel for smoothness?
I don’t know much and just know cheap ceramic can be disastrous. Just plain steel is good to me.
Welcome to the future of high temperature bearings - basically say goodbye to exploding ceramic bearings
Silicon Nitride (Si3N4) Ceramic Balls are formed from a new material suitable for applications where high loads, high speeds and extreme temperatures are factors. Long life and the need for minimal lubrication make this material appropriate for extreme applications. Silicon Nitride is non-porous, non-magnetic, non corrosive, lighter than steel and, in ball form, is harder than steel. Because ceramic balls are non-porous they are virtually frictionless and are capable of spinning faster than steel balls.
more info :
https://www.ceramtec.com/news/id/1843/silicon-nitride-ceramics-for-roller-bearing-technology/
retail 608s :
https://www.amazon.com/Si3N4-Silicon-Nitride-Bearings-8x22x7/dp/B073DP1QY5
wondering if harder=more brittle for these… probably ok in pneumatics, but I’d be pretty sacred to use them on urethane
Back on pseudo-rambling topic…
@moon donated a broke-dick 6374 SK3 to further along with this project, if you can recall there was some conversation early in this thread about whether Jerry used an SK3 motor for his Carvon hubs, and I can confirm that they’re very fuking similar…
Left 6374 SK3, right Carvon V4
In this pik you can see the bearings, screws, everything from the SK3 fits into the Carvon
One thing that delayed this was a concern of the broken magnet in the original can…
Upon receipt of the @moon SK3, the magnets are Identical, except for the 10mm length difference, so I went on a magnet harvesting project
I was able to free 5 of the little bastards with only minimal whining and whinging, now to bring out the diamond dremel cutting wheel and see If I can’t hack off approx. 10mm from the magnet and epoxy it into the Carvon can and battle harden the magnets in…
Battle hardening the magnets in seemed like a fools errand with a broken magnet…
stay tuned…
measuring inductance on the SK3 vs Carvon V4
SK3
Carvon V4
and as an added joke I threw the crappy Skullboard hubs into the mix
Skullboard
I have a pretty rekt but working 6364. Its an SK8 not a SK3 tho
thanks for this…
how nice for you!!!
even thou I mention SK3, it would appear that Jerry would have indeed used 6364 sensored SK8 vs. the SK3 mentioned above many times… hahahahahaha
makes sense, it’s a wild 245KV which after WYEifying is still too high at 144.11764.
these Carvon V4s are “supposedly” 113kV wound WYE, I say supposedly as I have not had a chance yet to run them and check kV… but soon-ish I shall…
113kV wound WYE would yield 192kV when would DELTA, I believe…
Curved magnet replacement… Thanks @moon… fitting an SK3 6374 magnet into an SK8 6364 Carvon V4
EDIT: supporting text added
As received motor rotor with the broken magnet, placed in a race glove and mounted in a vice
I got a very small chisel and smacked the chisel with a hammer 1/2 of the magnet came out with minor grief
Same with larger magnet piece, magnets out can is filthy
Broke dick magnet pieces
Cleaned up the rotor a bit, and pressed out the minor dent, as best I could, with a pair of welding clamps
Test fit @moon 6374 magnet into the 6364 Carvon
With a diamond cut off wheel in a dremel, I made quick work of that pesky extra 10mm
super clean the can
marked the proper orientaion of the magnet…
and glued the fucker in with a thin layer of JB-Weld magic ala @b264
now we drink and wait…
What did you end up using from my motor?
A bit more work on the Carvon motors… Nothing substantial just phase wire replacement…
Phase wires cut and cleaned
The soldering 12ga silicone wires
Finished… And wrapped…
You inspired me and I just finished servicing my carvon v4s. They had a weird clicking noise on both motors.
The clicking seems to come from the three screws behind the stator. Mine had become loose enough to let the stator rotate on the axel a few mm. Tightened those up and they feel good as new!
From reading other threads it seems like a common issue, make sure you tighten those screws and use some loctite.
Last thing I need is replacement spacers, have you by any chance found where to buy them? Standard skateboard spacers are a tad too big.
What size do you need? ID / OD / length
