FlexiBMS Lite - Flexible Configuration BMS w/ CAN-bus
After all, I found that discharge bypass was fine for me.
The premise of not using the anti-spark switch.
Demand for 14s, 16s, 18s will come soon.
I already have a plan for 14s ESK8.
This is because the 14s is compatible with an off-grid inverter rated at 48V.
This allows the ESK8 to be used as an emergency power source or an outdoor power source.
Overvoltage 64V. Low voltage alarm 42V.
I know you’ll argue the toss but pretty sure ‘configured badly then breaking easily’
The designer never sold them directly and they are open source…GB territory
They are not beginner BMSs, respect to Danny
Not hating on DieBieMS, it is a marvel(hardware wise), but the documentation was… well… lacking…
Which can be attributed to minimal user-collected documentation sadly. Let’s hope @SimosMCmuffin will make a much better documentation. :slight_smile:
I am quite sure Danny is even replying to user e-mails about DieBieMS, too. :smiley:
DieBieMS is awesome :heart: Let’s not forget that it controls discharge (not only charge) and as a result can precisely track consumed energy and report battery % based on capacity which is much more precise than voltage.
@Pimousse was kind enough to craft a manual with all the answers. I won’t back link to the yeuch place directly
https://drive.google.com/file/d/1cAlaAxA7yCMaTV4SlLBUlxvXA49OH1vI/view
And of course the readme on github
Also found this just now
You know @b264’s favorite knowledge place duckduckgo.com
@SimosMCmuffin apologies for the derail
Here’s the current list of available configurable parameters on the BMS and their descriptions.
its crazy that this motorbike carries the charger around all the time, just to save it shipping with a large external charger.
Wonder if you could make your charger so it mounts on your board for long group rides, saving space in your backpack.
For top mounted MTBs I think it would be possible. Like a piggy-back charger stacked on the main box. :thinking:
:pleading_face: Such much love :smiling_face_with_three_hearts: , and from others also :pleading_face:, thanks!
Just finished my backlog of BMS repairs, not that many just a few, most failed due to bad wiring or bad packs, but that kind of failure will damage any BMS connected to it. The problem with balance wires is that they can deliver quite a bit of current, also when that is undesirable.
They be golden.
Production boards are here with their ENIG ( Electroless Nickel Immersion Gold ) finish.
Some of the critical components are on backorder (battery stack monitor), but I have enough of my own personal inventory that I can start the assembly now and make what I can with the components I have on hand.
Storage discharging has been implemented in the FW and more can be read over here:
Also found a little improvement for the active mode current consumption with a better resistor choice.
I have some boards assembled, but I’m making/developing some improvements to my PnP machine.
@SimosMCmuffin So When Can I start to get my hands on ones of those boards?
53 posts were split to a new topic: What is your ideal BMS?
A post was merged into an existing topic: Forum Adjustments and Updates
why a resistor on the 5v line? that’s not the same as the terminating resistors is it?
what does safe mean in this context? safe from blowing each other’s can circuits? or safer can signaling quality? or??
why connect the 5v line at all? I thought he canbus just needed the two CAN wires connected?
IIRC connecting the 5v lines means that when one unity powers up it’s 5v supply this connection also allows the other unitys 5v line to get powered up, causing both unitys to boot together.
The resistor means it if any faults occur then your not causing a dead short on the 5v line which could cause damage the unitys internal 5v supply.
Fun fact: if you have push to start disabled, this doesn’t work.
Is this just a unity thing? or all vescs?
Why do they need to power up together?
is this a precaution against the fabeled canbus chipset burnout from powering vescs on at different times or what is it protecting against?
Its a way to get two unities to boot up from one unity switch. So yeah, specific to unities
The problem is the VESC has not implemented CAN BUS properly is shortened bastardised vershion from what I understood.
I think the resistor between the unity’s was some thing to do with useing 1 switch to turn on and off both unity’s. With out it when you pressed the switch the 1st unity would turn off but the 5v raile on the 2nd would take over and boot up the 1st unity again. This would leave you stuck in a cycle of not been able to shut down.
Bringing this back to topic I believe the DieBieMS had a solder bridge on the PCB the you could add or remove depending if it was end of line or in between VESC that did have a resistor unsure on the FlexBMS
Sorry that I keep comparing Flex BMS @SimosMCmuffin to DieBieMS but it’s the only thing I know that works in a similar way. I see both have there advantages in there own way not as a copy
