Evolve 6" tires?
thas nice
@Ukesu Dang, those look really good on the wider hubs. Making good use of those 2".
That’s exactly the answer I was looking for.
Ima go touch myself now
Thank you
Now these are 3Dservisas 3.75 hubs correct
Ohh this is interesting. I know I tried TB AT tires but they seemed a bit too wide if I rmebwr correct. These look good tho
They def are. The 4.65" wheels have beefier spokes, and I wouldn’t expect these tires to fit those.
It is a tight fit but it looks so good and ride is a lot better than urethane :slight_smile:
You’re about to get shot :rofl:
But yes. Yes. I strongly agree with you :metal:t3:
@olsyke once you switched to the correct 6" inner tubes, how hard was it to get the 6" evolve tires onto your hubs?
after inflating the tubes a tiny bit while allready sitting in the tires, it was quite easy tbh
Nothing some personal lube can’t fix I assume🤷🏻‍♂️
@sesat do you think these tubes/tires can be stretched on the superstars aswell, with @Pedrodemio 's adapter?
i kinda fancy the look, and it would help a lot with wheelbite issues, but it makes me wonder how there would still be room for the tube
https://forum.esk8.news/t/widening-wheel-hubs/14744/27?u=olsyke
if im not misstaken the hubs width increases by 10mm , and the bearing distance stays the same
I would love to do that!
i lack the experience to know if this is even possible / worth trying
but if i can find someone offering 3d printing services in EU i would definetly give it a shot
Been done, only question is if the tyres will stretch that wide.
i don’t know. here is a pic of metroboard 155mm’s on a stretched hub but i don’t know the details of the wide hub in the pic
@sesat any idea if them 155s fit on 3ds 3.75 hubs ??
i don’t know for sure, but i think they do fit with the right 6" inner tubes
what i do know
metroboard sells those 155’s with the intention they be used on their metroboard x.
the metroboard x features wheel hubs manufactured by sunmate, which are trampa superstar knock-off’s.
the knock-offs have the same dimensions as the real deal. (so much so that one might conclude that sunmate is the oem manufacturer for trampa).
the 3ds 3.75"s are intended to be a drop-in replacement for trampa superstar/megastar wheels
I-Guarantee-It
if i’m wrong @ahrav i’ll buy the hubs, tires, and tubes from you at cost
The man puts his money where his mouth is. Even if they don’t fit I wouldn’t fault you because your logic seems good enough for me. As @kook would say “For science”
Ahh I just saw you said 6” tubes… I have some for 6.5” trampa treads and now the metroboard ones… let’s see what happens. Just ordered them.
