Neversummer descent flex deck with split enclosures. deck has some holes filled with epoxy from an earlier enclosure. has a 30a braided wire running through the middle under the griptape. I will chuck in extra wire if you want to add more amps. Will also come with the small 10s BMS listed below.
It’s this one in “classic flex”
this is what it looks like put together
2 of these enclosures
https://eskating.eu/product/abs-enclosure-38x160x200mm/
one has a 13mm hole, the other has a 16mm hole and 2 12mm holes for motor wires. the deck is drilled to fit these enclosures.
£70. now £60. now £50
I get one question a month about this LIPO BMS setup so I am selling it here. it allows you to charge 2 5s lipos with a regular charger at the same time. charge only 10s bms.
- Free with the deck+ enclosures above.
Imax b6 clone charger. works perfectly.
£10
42v 5a charger SOLD
One of those xinmore 42v 5a chargers. works fine. The end connector is not included. I need it for another charger. will be bare wires. UK plug
£10
Kaly NYC enclosure SOLD
Kaly NYC enclosure for 21700 batteries and full ATB deck. This won’t fit the carver decks.
Brand new with 28xm4 inserts and matching screws + aluminium mounting plates.
£85
eskating.eu 42v 3.5a charger SOLD
eskating.eu 42v 3.5a charger. 5.5 x 2.1mm port. Fanless. EU plug
£15
Carvon exo drives SOLD
Last up is my Carvon V4 Exo direct drive. Very close to my heart and I don’t really want to sell it
. My first expensive purchase but alas, It has to go. I am just not using it.
Condition is solid 8.5/10. The urethane sleeve is spotless short of a hairline scratch.
Has 10mm axle. I will include 4 extra bearings for a total of 8 so you have some spare.
Has 9 pin connector. The adapter in the picture is not included. Its spoken for. If you really want it, I will sell it at cost for £15.
Has the ABEC clone adapter so you can use clone wheels or add head shrink on the prongs for real abec cores. I am fairly certain they will fit the discovery cloudwheels too. The measurements line up though I haven’t tried them.
Here are the specs. Mine is confirmed 84kv.
Priced a £250 + shipping
Video of it running below
iWonder Discovery 120D Cloudwheel discussion - #44 by BillGordon
Prong dimensions suggest a good fit for discovery cloudwheels.
Trampa hangers and baseplate SOLD
2x trampa ultimate Full ATB 16 inch hanger + 1 baseplate + 2 kingpins
one hanger has motor mount marks.
£80.
will split if you only need one.
5045 Drive train SOLD
Wheels NOT included.
just not using it and its gathering dust.
Has 200kv 5045 motors, on slick revolution mounts with belt covers. Original mount has 30mm mounting holes so I used a round file to expand all holes to fit 38mm. works fine.
gearing is 15/39 on abecs pulleys. also includes a generic front truck. has about 40 km total.
price is £99 for front truck, rear truck with mounts+pulleys + motors.
pics from this morning
Here is a video from a few months back.
flipsksy lot SOLD
Next up is this lot:
vx1 with 500mah battery, 2x 4.12 flipsky, eskating.eu antispark switch with 40a fuse, flipsky Bluetooth module, canbus cable, xt60 splitter. Everything in great nick and fits the above drivetrain like a glove. £99 ------ SOLD
Shredlights SOLD
shredlights OG with extra set of brackets and original charging cable
£15-------SOLD
IdeaTB v7 mounts SOLD
IdeaTB V7 trampa full size truck motor mounts + pulleys with idlers and no cross bar
includes 2 spare new belts + the motor pulleys are upgraded steel ones from eskating.eu
Gearing is15/60T and 8mm motor shaft. Only surface level scuff marks. No deep scratches or anything. Hanger not included.
£140
