Shipping for small items is between 10 and 20€ in the EU. For large items ask me for a quote. Outside the EU it’s from 15 to 40€ depending on the destination.
Motors
6880 Maytech 180kv motors with support bearing from Bioboards – 240€
180kv
25cm phase wires
35cm sensor cable (no adapter needed for vesc)
5.5mm bullet connectors (don’t recommend changing them due to wire enamel)
40mm shaft, 10mm in width. 19mm keyway slot
(I believe these are battle hardened from the factory, but haven’t opened them up to be sure)
Unused, just tested on the bench just now prior to selling. 1 motor sounds like the can is scraping against the stator a little (ironic, considering these have a support bearing). I’ve included a video showcasing them working / the sound:
Reason for selling: I’ve heard some reports of these motors not being good in wet conditions due to the outer bearing, and I need motors with an 8mm shaft for my build anyway.
Price: 240€
Decks
DB Longboards Freeride DT 38" – 50€ SOLD
Sold
Painted in Orangutang blue by yours truly. Viscous grip. If you don’t like it, I can throw in a sheet of electricboardsolutions griptape for 5€.
Has 6 shitty aluminum M6 threaded inserts underneath, and a silicone mat glued on. + some velcro straps for securing a battery.
Edit: I removed the silicone mat and strips to use it as a push deck. 5€ extra if you want these trucks and wheels. 5€ more if you want bearings
Comes with free ABS enclosure and bolts.
Enclosure pics & dimensions
Enclosure is from esk8.de
Enclosure internal dimensions are 495mm x 145mm x 24mm
Price: 50€
JJ Boards 40" super stiff, 13 ply downhill double drop deck – 90€ SOLD
Sold
Weight: 2.3kg
Guy who drilled the truck holes in it was high at the time, so we had to redo it.
Grip is a combination of medium and harsh.
Price: 90€
ESCs
Enertion Focbox v1.6 in semi-working condition – 30€
- I had to cut off its CAN chip after using it in a double setup
- It can’t measure its mosfet temperature anymore. Reports a constant 25 degrees, so be ware of using it in a setup where it might accidentally overheat.
- I replaced the phase wires with long ones with 5.5mm bullet connectors. (Can include 4mm if you want. 5€ extra to solder them)
Price: 30€
TorqueBoards 4.12 vescs SOLD
Sold
55€ for a single, 100€ for 2 (Third was is getting DRV errors, comes free if you buy the others)
They all have XT-60s and 5.5mm bullet connectors.
Price: 55€ for 1, 100€ for 2
BMS – 12s 80A Bestech HCX-D596 – 40€
It is currently attached to a 12s2p battery; I will unsolder it if it gets sold. Shipping the whole battery is hard + it uses cells people wouldn’t want. Here’s a picture of it currently to prove that I have it, and then there’s a photo of the battery being built.
Price: 40€
Junk
12s Li-ion fanless 1.5A charger – 10€
Has a 5.5 x 2.5 plug, can include a couple charging ports.
