How far from the car was the broken board?
How did you get out of there?
I was about 5 miles back. Had to sit on the board and gravity down the hill using my feet to brake. I was still able to accelerate a little but braking with the motors instantly locked up that side. Tailbone is a little sore but it beats walking!
I always lick my fingers after working on my board. If it taste sweet it meant I touched Loctite at some point. (Or lead)
I’ve just been smelling them. Time to step my game up…
@SirVesa do you have any info on Pismo Beach? There are 3 trails there, 2 along the beach and one up in the hills. My question is how friendly the area is to esk8ers?
Thanks for any insight.
Pismo is nice but it’s kind of a tourist trap. It’s very crowded, especially on the weekends. You could probably find some good places to ride during the week. I would avoid the Bob Jones trail though, that one gets packed.
I run away from packed trails. Fortunately we’re going to be there mostly mid-week. I am primarily interested in Octopus Oak.
Avila Beach trail is 20 miles long, do you think there are sections that aren’t so crowded or is the whole thing a zoo?
Are there any eMTB friendly secret runs between there and Santa Cruz?
Thanks!
You might be alright during the week. Haven’t ridden there before though. The only trail that we frequent in SLO county is wrecked right now. Point Sal in SB county is another 30 minutes or so south from Pismo. It would be well worth the drive time.
It’s usually better to just not resurface the road at all, instead of using chip and seal. And it’s a whole lot cheaper to leave it alone.
Yeah Refugio Road isn’t the same. Even worse, they skipped the last step of chip seal road construction and didn’t return to hit it with a sweeper. It’s going to take a lot of rain and time to clear all of the loose gravel.
@DougM here’s the location of the start of our Point Sal run. No chip seal on this ride. The trail is in pretty good condition right now. It takes you to one of the nicest beaches in our county and will be empty mid week.
@SirVesa thank you!
It has been a recent stream of frustration trying to get the final kinks worked out of these SLM gear drives. The gears themselves have been great. I have two jump drives retrofitted with herringbones and the new selection of tooling steel for the motor sprockets on my chain drive are doing well so far.
It’s the damn aluminum that is giving me headaches. I can’t get a clean M4 tap in the new batch of gear tubs from 3dPNXT. It does tap, but the threads are way too easy to strip and I don’t feel confident having weak threads in a structural connection point. The stuff I ordered from Shenzen 3D was MUCH easier to work with. Choosing the right manufacturer is important when getting anything made, but I can’t count on Shenzen 3D to always be in business and there’s always a chance that something changes in their manufacturing process that could result in lower quality. Next solution (when I can afford it) - NO MORE STRUCTURAL TAPS IN THE ALUMINUM GEAR TUB.
Here’s the proposed solution.
12 of 4mm diameter pegs on the truck clamp.
4.2mm openings on the gear tubs.
Everything tightens up with the axle nut.
The same thing could be done to the gear adapter so that the hub adapter just slides onto it.
There’s still enough angle adjustment to make most people happy. I think this will have plenty of strength, even with using aluminum for the clamp. If it does break or feel flimsy, the diameter of the pegs could be increased or this part could just be ordered in maraging steel. As an added bonus, this cuts a good chunk of assembly time eliminating 17 taps and the 4mm bolts that would normally make this connection. IF this works out, it could be the final version of these drives. Can’t see why this would be a bad idea but please speak up if you see why it is. It might save me some money and pain…
If the issue is small features in this aluminum part being weak, then I think you’re likely to have a similar issue with those thin aluminum pegs.
How about instead, you have the part made with slightly undersized holes, you drill them out to something accurate, and you press-fit steel dowel pins into them? Like the old boardnamics pulleys.
Yeah the issue is getting good m4 threads. The M6 taps just fine but the M4 just feels too fragile.
That’s not a bad idea. Could probably just print the entire truck clamp in steel. It wouldn’t really cost much more and the weight should be negligible on such a small part. Appreciate the advice!
Armchair mechanical engineer here, seconding Benjamin’s motion. Why you always gotta be so smart @BenjaminF ?!? ![]()
I share the concern of the aluminum pegs fatiguing off. Especially under fully reversed cyclic loading (accel & decel cycles).
Looks like the parts have enough meat to press in steel dowel pins. Dowel pins are cheap & easy to get, and tightly toleranced. Print the holes undersized, find the perfect reamer for your press-fit and voila! Could even fix them in place with green retaining compound.
Awesome project by the way!
Yeah that idea hadn’t even crossed my mind. As an added bonus I wouldn’t need to order new parts. These could be reamed out to fit the dowel pins. Can you see any advantage to using dowel pins instead of just printing the entire truck clamp in steel?
The dowel pins are going to be significantly stronger than the printed steel pins.
Will you need that much extra strength above and beyond the strength of 12 printed steel pins? No clue! The dowel pins could be massively overkill. But without knowing how overkill they may or may not be, my instinct is to go as (potentially) overkill as reasonably possible.
It’s such a cheap fix too, $10 for 25 of them on McMaster Carr. I’ll give this a shot.
Try the dowel pins but I wouldn’t rule out the full steel version.
Beauty of steel is it has an endurance limit. A level of stress (typically around half the tensile strength). You can expect infinite cycle life for stresses below the endurance limit. ![]()
Aluminum has no such thing. Instead, every load cycle (no matter how small) does cumulative damage… eventually leading to breakage.
Regardless of material, the chamfer you have at the base of the pins should serve well against stress concentration – at that expected failure location. ![]()
OK that makes sense. So if I do this without ordering new truck clamps there will only be four steel dowel pins making that connection. The ones I have do not have a ring of holes all the way around them. Options would be to try it like that, order new truck clamps with a ring of holes to use 12 dowel pins, or to order the truck clamp in steel with the printed pins. Unless you guys think four pins is too weak I’ll give that a shot first. That connection is made with four of 4mm bolts in other truck designs…
