Yeah I say try it out with what you have. Doesn’t hurt to do the easy thing first.
Callout to @SirVesa for actually being the nicest guy in Esk8. Through some miracle of fate that I still can’t fathom I actually ran into him and his friend on the Point Sal trail. Not only did we have a couple of great discussions but when I (finally) got to the end of the trail he handed me a beer.
Thank you!!
I’m back in Seattle where it is still raining. But it was great riding California
Glad you enjoyed the trail! Would have had a better beer for you if I knew you were going to be out there.
Another major failure in the SLM drives today!
That grove shown above was not made by anything rubbing against it. And it turned out to be more than just a groove!
The new truck mount with the pins is holding strong. The holes in the gear housing that the truck mount pegs slot in to look pristine.
Nothing inside the gear tub lines up with the failure hole. There’s nothing that could have cut through it with rotation. The bearing rests on a seat and makes no contact to the enclosure wall. No signs of wear on it.
I think the inside wall of the gear tub is too thin to handle that much force and started to break after that hard impact I had on the first ride. It only looks like a hole saw cut because it spun back and forth with the gear rotation, kind of filing itself.
So it’s back to the drawing board. Easiest fix I can think of is to use a harder material for the gear housing, like 704ph stainless or maraging steel. That’s going to add some weight though. Another option is to redesign the housing with a few mm thicker wall. It would add weight too but probably not as much. I’m calling this a win though for the truck mount with the pegs. The fact that none of the pins bent before this happens gives me some confidence in their strength.
So basically the choices are new stronger material, or thicker housing…
Wow! Its actually quite suprising that it broke in such a clean circle! I know the filing effect would have helped it look like that but it’s still very circular!
Yeah I was really confused until I got it on the bench. 100% nothing did this with friction. I’m leaning towards same drive with stronger material. The experiment continues!
This is good data!! Keep it up ![]()
Absolutely will do. Wall thickness was around 2.5mm, which I thought would hold up. The SLM gears have been epic, trying to design a complete SLM housing that can withsand mountain boarding is getting there but it’s a constant stream of reinforcing failure points to expose other ones. Not complaining at all, it’s been a fun process.
So I went ahead and ordered replacement housings in steel because I thought working the model to increase wall thickness in that area was going to be kind of a chore. Turned out to be a lot easier than thought.
This is the original file.
Beer Drives Remastered PUSH FIT VERSION FEMALE GEAR ADAPTE
Here it is, reworked. That wall that failed is now 4mm thick instead of two. Everything else should work the same.
Beer Drives Remastered PUSH FIT VERSION FEMALE GEAR ADAPTER 12mm Height.FCStd (1.5 MB)
The steel version is already ordered, but I’m very tempted to add two of these as well. An aluminum finished product just seems better since it can be anodized and saves weight.
These experiments aren’t cheap and I really appreciate all of the advice some of you have given. Would you prefer a more compact gear drive that is slightly heavier, or an aluminum one that would take up 2mm more hanger space?
Have you considered cnc machining the housings? From my perspective, it seems like it makes the most sense to just SLM the gears (which can’t be cheaply machined) and cnc the rest (which can be cheaply machined). But have you run the numbers and found this not to be the case?
It’s crossed my mind, but I’m stubborn and the goal is to make a full SLM drive. If using the same material and increasing that wall thickness from 2mm to 4mm doesn’t do it then I’ll try the steel version back to 2mm walls. Both versions have been ordered. If both of them end up failing, looking into machining the housings might be the next step. Then again, there’s always SLM titanium…
I’m optimistic that just increasing the wall thickness will do it but we’ll see…
I’ll do Benjamin’s idea for you ![]()
I checked prices and they really aren’t much different, and that’s using 7075 instead of 6061. If you’re really going to do it though, you’ll need to adjust the bearing seat diameter because it’s set for SLM tolerances. Same with the bearing pockets on the gear adapter piece.
I’m thinking of using 3d printed gears + a billet motor mount and hanger clamp
Considering herringbone Jackson drives
That would be sick. I know a PDF is needed along with the STEP file when getting something made, but haven’t really looked into how to do it or what information is required yet. I might be bugging you and some other forum members for advice if these latest SLM housing models aren’t up to the task.
