The hubs don’t retain the bearing well enough and the slop turns into wobble.
They made a video about it 6 years ago How To Fix Clicking Bearings || Evolve Skateboards - YouTube
So you would think they fixed the mold.
Otherwise even if you shim the bearing some of the ones I have still wobble off center.
Received mine secondhand so I don’t know how old they are.
They have not fixed it, as it still happens on the Hadean.
I’ve just stopped using mine altogether. I look else where for esk8 parts now and try to stay away from anything evolve.
Nacho
June 2, 2022, 2:54pm
#4
These look promising for a evolve rim swap
They do. A 47t gear is what I use now. Not really into stretching the tires though and they don’t have the drive gear bearing?
Nacho
June 2, 2022, 3:31pm
#6
Maybe you can find some bergs with @moon @longhairedboy 47t pulleys
Google form https://goo.gl/forms/2QcSSmIGRyEDA0fM2
15mm belt width
6061-T6 Aluminium Black Anodizing
$75 for 2 pieces
Bearings
For use with 8/10/12mm axles
638 (8mm inner diameter / 28mm outer diameter / 9mm width)
16100 (10mm inner diameter / 28mm outer diameter / 8mm width)
6001 (12mm inner diameter / 28mm outer diameter / 8mm width)
[image]
[image]
[image]
[image]
But I don’t know if you will have enough axle length it could be a trial and error thing so it might not be worth the money
You can’t use standard tires with bergs though, right?
Why is this hub thing such a mess? Can’t they just make a good normal hub for 6" lol
Nacho
June 2, 2022, 3:39pm
#8
@Savage1 makes kegel pulleys for pneumatics
[image]
[image]
[image]
[image]
[image]
[image]
[image]
Hey all, I’m currently making a batch of precision machined Pulleys out of solid 6061 aluminum bar stock (so, one solid piece) to fit standard kegal cores, for a press fit application. There are 5 machined pins, 22mm length with a 1.6mm radius at the bottom. The pin diameter is 5.5mm held to a tolerance of +- .015mm. There is also a 22mm bearing seat bored to a depth of 7mm to accept either 608 bearings (8mm shaft) and 6900 bearin…
Nacho
June 2, 2022, 3:41pm
#9
Yes they only fit 6x2 clevers or if you can find the OG haggy tires
What about Metroboards hubs?
Swap the bearing for 8mm will they fit an evolve/vereal setup?
Nacho
June 2, 2022, 3:52pm
#11
Good question @jack.luis is the metro guy but if they fit on their Dkps they should probably fit on evolves DKps
InfinityHubs are the best I’ve used so far. they have all the mounting options, easy tire/tube swaps and with some rim tape I’ve had no issues with blowouts.
Yes but they are all sold with 10mm bearings not 8mm
I mean if you can swap them even with a press that’s not a big issue
tech.shit:
InfinityHubs
jesus that’s the price for one hub?
Price for a set of 4, who TF buys/sells hubs individually?
Too bad they’re out of stock
Hit up @surfnacho and see if there will be more soon.
