Bahahahaha! Pass.
OnlyFans is the only way you pay now?
I donāt normally sell them, but I have some big boy 12S ones 80Ć60mm for when I need to be able to charge 8A+. I can ship immediately, but not trying to undercut, so same price as Kevin.
Iām not making $4. After shipping. This is purely for a favor for everyone. By all means. Sell away!
Still have the 12s bms? Iām leaning toward a bms failure with my 12s battery. Still researching but stopped taking a charge despite balanced p-groups and continuity where it should be present.
it looks like that 10s gave up quite a fight, opening it up!!!
I was going to open up one of my Daly BMSās to reroute the wiring⦠but I guess I wonāt be doing that nowā¦
you can get it to fit if you try hard enough
I got it to work. Cut a small piece off the end with a knife
Still happy to send you a 13 pin / 12 s connector⦠Or anyone⦠Should just be 2 stamps/ envelopeā¦
for the Daly bms, where are the P+ and B+ leads? I only see P-, B-, and balance leadsā¦
Iām really into the idea of having a US based stock of BMSās.
Could I buy 2x12s and a 10s Daly boi?
Iām going to be buying 16s only from now on. You just bridge the last wires to compete nthe circuit. Same size as the 12s same chip. @Winfly helped me on this. Ordering 30 of these and 20 12s to those who are skeptical of soldering the last 4 pins/ wires.
A bunch of pinions too. And bolts/. Etc.
Give me a 2 weeks.
Itās charge only. No need for the other. One for the charger. The other goes to battery. Thats it. Simple and quick
Iām down for 2x 16S
@kevingraehl samezzzz 16s
Just sent $505 bucks. Took two weeks last time. Once I get tracking. I can spare some of my secret stash
Dayum⦠das sum quikidy quik ship.
Iāll be in for 2x 16s
I opened the 12S bms and found the data sheet the IC they used. they always populate all 16S and the IC is capable of 5-16S without any Selection pins. The way to adjust is like this diagram
Shorting the extra pins to the highest voltage pin.
