As much fun as this setup for discharging is, it’s way too slow… I can’t plug in anything more power hungry, the inverter is old and can’t take more.
What else from around the house I could plug in straight to the 19v pack to discharge it faster? I don’t have any high watt resistors and I’d rather not go shopping for this…
Going for a ride is not really an option, I’d like to sort the pack out before assembling the board.
Nope, couldn’t find something useful at home. Ended up at a grocery store and picked up a few halogen light bulbs. Unfortunately I could only find 20W 12v ones so I connected 4 in 2s2p configuration to discharge the 6s packs.
So far it seems to work, it’s pulling about 55W (3A).
I’m going to run both 6S packs down to 2.9v per cell group and then connect them back to the LLT balancer and see how they behave.
There seems to be some sag with this 50w light setup but I’m thinking it’s normal.
I ran the cells down to a little under 2.5v and after taking the load off, they slowly climbed back up to around 2.9v. Can they be considered discharged now or should I run them lower until they stabilize without load at 2.5v?
The industry standard for capacity testing is discharging at a 0.2C rate (e.g., a 4000mAh cell would be discharged at a 800mA rate) from 4.2V down to 2.5V. For capacity testing it’s much easier to get a cell to 4.2V via charging than trying to bring it down to 2.5V.
You can go in reverse though, charging at 0.2C rate and counting the mAh put back in, but the number you get will be a bit off. Okay for general health checking and comparing cells against each other though.
Discharge your cell(s) down to 2.5V or a little lower at a slow rate. The voltage won’t bounce back up much then. You don’t need to get them to 2.500V as you’re not doing formal capacity testing, just close-enough numbers.
Well, looks like I may still have to take one of the 6S packs apart.
I was discharging slowly (0.6A) and about when all cell groups got under 2.6v one of them started dropping fast. Within 10-15 seconds it was under 2v. Stopped the discharge and it slowly climbed back up to a little over 2.
The other 6S half seems fine, all the groups stayed close to a little under 2.5v.
Is there a point in charging the pack back up to see how much goes in or having one group lose voltage so low is bad and I’d have to replace the cell/cells from that group first?
So one of the 6s packs seems fine. I’ve been charging it at 1A (0.2C) for over 5 hours now.
A bit surprised that we have already put over 5Ah in… this is 6s2p and the cells are rated at 2500mAh. How are we getting more capacity?
I’ll let them get up to 3.6 and we’ll see about the other 6s pack tomorrow. I’ll probably charge it up once but I am a bit worried about that p-group I mentioned above that discharged too low.
Slightly different topic. I got in touch with the manufacturer of the spot welder I used and it looks like I may be able to get a refund on it. It’s advertised as capable of welding up to 0.2mm but it won’t even do properly 0.15 pure nickel strips.
Anyway, the point is, I’d like to get this right. What spot welder should I get for this and future pack builds? Ideally it should do up to 0.3mm strips and it can either come with its own battery or be able to work with 6S LiPos (I have a few spares). I don’t have a spare car batter so lead acid or similar options are out.
Only does up to .2 and can self-destruct if you don’t modify it before the first weld. It’s easy to fix up but not for everyone. I had to add a cap and some copper to beef up the traces. Probably use someone else’s suggestion lol.
It might work, I don’t mind tinkering with it and I do have some copper bars…
On the other hand, I might just order a kWeld kit but not sure how long it would take for shipping from DE. That and I was hoping to use some 6S Lipos I have… I read that kWeld works better with lower voltage input. We’ll see, I’ll do some more research.
Back to our packs… slow progress. Yesterday we decided that one 6S half is good and today we’re charging up the 2nd one. This 2nd one I’m a bit more worried about, it’s the one where we saw that one cell group get charged much faster initially and then here we also have another cell group that discharged much lower, under 2v while the rest were at 2.5v.
Right now it’s charging back up and we’re at about 3.35v. Once it gets to 3.6v I’ll discharge it one more time all the way and if that one group gets that low again, I’ll have to replace it.
The 2nd pack charged up fine, we ended up putting in almost 5600mAh and the p-group which ran high first time, was fine now. It probably needed a good balancing…
Moved on to discharging it.
The p-group I was worried about, the one that discharged too low, died completely this time. By the time the rest of the p-groups were down to 2.8v, the bad group was already below 1v.
Surgery it is! “Luckily” it’s group 6, the one from the rear end so it was easy to remove without damaging the rest.
Now, I do have a bunch of spare cells but I want to make sure I choose good ones. What’s the best/quickest way to test individual cells? Should I just make a 1s2p group and discharge it to see how it behaves?
If you plan on doing more battery building you should get a cell charge/tester that can do a capacity test. Quick and dirty check would be to check the voltage of any cells that have been charged and let to sit for a week and see if they are self discharging.
Side note: What’s funny to me is that smaller packs with fewer cells in parallel are actually harder than larger packs. With 4 or fewer cells in parallel you have to be more precise and careful about matching cell capacity and IR characteristics. Also the connections and nickel strips need to be perfect as any defect in placement or welding doesn’t have the structural advantages of larger groups. If there are any cell mismatches the increased load placed on lower pgroup builds per cell causes them to wear even faster and get into unbalanced or over charged/discharged states. Rant over lol
I would suggest fully charging the prospective cells if they aren’t already. Checking them after a week of sitting for self discharge.
Another good test is voltage drop over a common load which is a way of testing IR without testing IR. Separate your FULL (important that they are fully charged) cells by exact voltage - test to the hundreth of a volt at least but you want as much accuracy as you can easily manage, then take some of the closest matches and put them on the same load for the same amount of time and check the voltage while under load. I usually load my cells for a full second or two but not much more than that with a clock running so I don’t have to count and record at the same time. You want this first and second voltage measurement to match as closely as possible. Use a resistor or non fluorescent or non led light bulb, a fan, a heating element. Just so long as it will only load the cell below its rating.
Take two that match best and make them kiss, they p group buddies now
Indeed. This thing is turning out to be quite a pain but we’ll get there.
For sure I plan on building more packs in the future so I’ll get a decent welder and tester eventually. Now I just picked two random cells from the left overs and I’m going to charge them up.
I’m starting to feel like in those time loop movies where same things just keep happening over and over. Now, while I was messing with the spare cells, I put those halogen bulbs to discharge the “good” pack again just to double check. Low and behold, now a p-group from that went too low. All the rest were at 3.0 and one group started going below 2.5 quickly. I stopped the load and it started to recover but this is not a good sign… I need to look into this now again
Recycle batteries are way more work than new cells and require significantly more equipment and effort to make work well. I just like doing it fsr it doesn’t seem cheaper than new cells to me.
I wont use a used cell I haven’t tested throughly, been burned (figuratively) too many times.
For just cell charging and basic capacity testing i use the opus 3100 and 3400 chargers, takes time to do the discharge test but it is repeatable within about 5% in my experience but don’t trust the IR test for any of the smart chargers. You can set the voltage on this charger so it will do lifepo batteries, there is a switch on the pcb you can flip to make it work correctly BUT it will kill cells if it is set wrongly. (Probably why it isn’t easy to access or a published feature).
Good ir testing results can only be obtained with dedicated higher voltage test equipment but the test I described in the above reply will work with just a few dollars in parts - just remember to test multiple times: cell 1 then cell 2, then cell 1 again and cell 2 again. That way a bad or accidental high resistance connection doesn’t throw off your measurement.
One more question on these, trying to understand. Before taking apart the “good” pack because of that p-group which started discharging too low.
Is it possible this happened because the pack was never completely fully charge and balanced? I did stop charging at 3.6 so is it possible that one group was not actually fully charged and when I did the discharge exercise, it just ran out of juice faster than the others?
Trying again now to fully charge up the pack and I’m going to leave it on the charger until it’s happy. We’re doing it at 1C now so it shouldn’t take long… the balancing part, I’m not sure.
I’ll be honest, I’m getting a bit tired of messing with this pack. I did charge/discharge the random replacement p-group cells and they seem to behave so I welded it back into the pack and wrapped it back up.
I connected back the LLT BMS and I’m going to leave it alone to do its thing. I know there’s a bigger delta but that’s because I was separately charging/discharging the two 6S packs.
If it looks ok by tomorrow, I’m going to move on to connect the vESC, remote and motors.
The balance current is like 50ma so it might take a day or two for initial balancing. Let it do its thing and then look for problems. It can’t be rushed easily so relax a bit, i had assumed you were working with a balanced pack. You can’t tell if discharge is un balanced or wonky until it is first balanced and this can only happen at the top of the charge cycle. An unbalanced pack in the middle of its discharge is going to look scary bad and part of why balancing is so important. My recent battery build took a week to balance iirc
