@poastoast reee
weee weee bb zooooom
i want straights
anyone have an stl of the bn m1 enclosure? i’d like to model up some skid plate/motor guards. the clearance is so tight even on 105mm wheels
.stl AND .steps! you da man
Bruh, just send him an email.
Hi Mr Namics, I wanted to ask you a question. Can you please tell me…
HI MISTER KEVBALL. WHERE IS MAY ORDER? THANKS.
Thanks
This isn’t that far off from several messages I’ve sent him
M1 straight cuts and reachers . Love that sound.
Pinion gears slightly too big though, so can’t fully put the case on. Think I’ll need to grind it down ~2mm or get a new pair.
if your issue is what I think it is, all you need is some aluminum shims to space the shaft out… reachers have a step at the bottom of the shaft that prevents the pinion from sitting low enough
2 per side of these bad boys did the trick for me
It’s sitting flush against the mount, but its taller than the case. Trying to screw it in just sandwiches it between the case and the mount.
Like @haven mentioned it’s likely the pinion sitting higher due to the small lip that reachers have at the bottom of the shaft. I also ran into this issue and used spacers between the motor and gear drive.
Unfortunately, that is not the issue. The pinion does not fit inside even without the axle/motor connectored. It too big for the case
Show a picture of the pinion?
Try pointing the collar bit inwards towards the motor
Depending on your motors, it may work in some cases, since the shaft extends a little bit below the motor mounting plate
The motors should not effect the pinion itself fitting inside when they are not connected to the gearbox. I cannot fully close the case with just the pinion inside
