Hey guys,
The new shipment has arrived and there is a lot of goodies I am almost ready to release. This will serve as a little teaser/update as to what is coming this month.
M1 Gear Drive
The final version has arrived. The M1 stands for Module 1, the size of the gears
Price is 159.99USD for a dual. $229.99 for a dual + 220mm hangers
Single drives will be $89.99
Specifications:
Materials: Hardened alloy steel gears; all components machined 6061-T6 aluminum
Gears: Straight cut only (for now). Helical coming soon. Ratio is 2.8
Wheel compatibility: Kegel, Flywheel, and Bergmeister
Hanger compatibility: Boardnamics 184mm, 220mm, and 270mm precision hangers ONLY
Clearance: The case is 72mm in diameter. 97mm wheels or bigger recommended
Very happy with how these turned out. Extremely low rolling resistance because the seal is a unique bearing+o-ring combo. Amazing sound, like a sports car
Excited to share them with the world.
Matrix II Mounts
Price is $79.99 for a set(2)
New version has arrived with a few changes:
The overall quality is significantly higher than V1. Sandblasted black anodized.
Optional holes for Idlers
44T Kegel Press-fit Bearing Pulleys
Price is $49.99 per set (2)
Same reliable design as my other bearing pulleys.
Compatible with evolve boards with optional 10mm bearing
ETA 1-2 weeks
Steel Motor Pulleys
Price is $8 per pulley
Material: Black Oxide Steel
15mm wide, keyway included
2 M5 set screws
No shoulder
14T, 16T, and 18T sizes
Other news:
Fixed axles came in, sending backorders now.
More motor mounts and precision clamps are in. More precision baseplates are in.
look nice.
