I have plans to make a “beefyish” version soon as time permits, as well as a whet version with wheel slpashy splashy guards! (atm that would likeliy take a goooooooooooooooood couple hours to print, but it’ll improve over time, might make different versions for anywhere from 97-110mm wheel diameter)
I print mine @ .2mm layer height, @ 32%+ infill, but use your own judgement.
If you don’t have a printer and want some, just hit me up!
$8 a pair + shipping (should be roughly $8 as well, depending on how many you’d like to cop)
Thank you! I had been meaning to design and print some of these and these look great Honestly might hit you up because my printer is broken, I’ll let you know
@poastoast , you may want to increase the thru holes from 4.0mm exactly. Typically, close-fit 4mm thru holes are 4.3mm dia.
If it’s designed to use the bolt head as a retainer, no need to make it an interference fit as well.
Also, regarding fasteners:
The M1 GD uses M4x12mm long bolts. The thickness of these guards is 2.4mm. With the 15mm long bolts you recommend, you’re going to have some extra length poking out the other side, on the front and bottom fasteners. Depending on the clock position of the motor, that extra length may put pressure on the motor cabling, which is pressed hard up against that plate.
I’d recommend decreasing the thickness of the guard to 2.0mm exactly in order to use 14mm long fasteners without any potential interference. Or you could update the design to not use the fasteners at all. VHB tape or silicone adhesive will probably secure these just fine, potentially better spread over the whole inside mounting face.
Very interested in these XXL versions if you’re selling them. Went down to 100mm wheels and my drives and motors are taking a beating. These look perfect for the 6355s I’m running.
you’d like the guards to completely cover your motors? or were you talkin bout the AT version (i have that in the works rn) i think i can do
i’ll get to it soon as i’m off work, got lots to do!
