Bioboards Thorium X4 AT Ferrari Edition - possibly the fastest eks8 ever made!
So i wanted to make the fastest electric skateboard ever made and rided!
So i build a special version of our Thorium X4AT.
It have:
Helical gear drives from @3DServisas 1:2.2 Ratio
270mm hanger from @3DServisas
165mm AT tyres
13S6p battery (will later change to a 18S4p 40T)
Dual Unity
Adjustable Baseplate by @mikenyc
Evo 40 skinned by @Sender
4x6374 220KV motors but with bearings changed to work on higher speeds.
Bushings from @RipTideSports
Evo enclosure @eBoosted
Before first test ride i was afraid acceleration would feel to low, but it was still great thanks to 4wd!
The sound from the new helical gear drives is alot lower now so that was nice to test because that is what you will se in the new board from us that will release soon.
After first test ride did take it easy but hit 50 mph easy with alot of speed still left and when tested on bench i hit 78 mph with no load and 80% battery.
So should give some nice topspeeds when changing to 18S later!
I built this board mostly to celebrate by making a special edition how popular Thorium X4 AT was first s year but also to try ride fastest ever done a little later!
Here is some pictures, il post videos later when I have done the record if i survive :sweat_smile:
You guys are insane :metal:t3:
Really cool though, it’s clear lots of thought and effort went into this. Well done, and im excited to see what its able to accomplish
What esc are you using? What are you planning on using for the 18s?
Unity for now, will se whats available in future so nothing decided yet!
Not looking to hate! Your boards are totally insane from tip to tip but I really hope you guys can do something to make this look just a little nicer :grimacing:
Damn is that a 15° angle or what? Looks almost like 0
What angles are you running? Evo angles and truck angles together.
Also what bearings did you guys switch to on the motors? Curious
78 mph bruh I barely drive my CAR that fast on the freeway lol that’s insane
Nah no problem. It’s called Autobahn. :crazy_face:
PURE SEX!!!
The Bioboard widowmaker 125km/hr on a eskate, I want to try that only once
Lol yeah Germany has that cool thing huh
In California most people who don’t get tickets drive 70 to 80mph (mostly 65mph speed limit), the ones that do get tickets drive 90+ and weave in traffic
In some states (Virginia) if you drive over 80 you can get arrested lmao
Without wobbles?
One pothole and you might only get to try it once :joy:
Was no wobbles at 50 mph on flat ground atleast, will try step by step a little higher!
I think it is fair to say that @mackann is testing @Deodand’s new esc. I don’t want to see people sticking 13S on a Unity lol
Sadly we can’t disclose any specs, please be patient.
I got pulled over doing 120 in a 40. There was a good reason and it’s the only reason I didn’t go to jail.
Yeah I think 30 over is possible jail time in CA, not super sure
A board set up properly will rarely or never experience wobbles.
