Any news? .
Shipping in late Aug for delivery late Sep / early Oct. Sorry so long!
Can you shed some deets on your new deck? Looks a bit thicker so Iâm excited to see whatâs inside ![]()
I noticed a wierd issue with braking on FW5.3 Unity. When braking and coming close to lower speeds one motor starts to go in reverse. Not full throttle reverse but much higher than 7% set for smart current with reverse. It does this for about 0.5s
Looking to use epoxy on my motors. Since they are battle hardened, the rotor is epoxied but the windings are not. I want to do this since I have a wierd noise at low RPM, replaced the bearings and itâs still there. I want to epoxy the windings to see if it fixes things, can I safely use epoxy in the hall sensors or should I avoid them?
Whatâs inside? Special sauce of course. All I can say itâs awesome. Returning to snowboard style construction like some of our Pro decks from years ago (Pro 100 / Pro 95). Indestructible. Super fun. Thatâs all I can say for now. Youâll be seeing more before too long though⌠BTW, Iâm going to be traveling for a bit so responses will be delayed - even more than usual ![]()
I would use MG Chemicals 4228 (red insulating varnish) for this actually instead of epoxy. It works really well.
Either that or epoxy you can put on hall sensors. You can cover every part except the bearings or bearing seats as long as you donât block clearance for the rotor to spin.
Hello! Could use some advice! Want to solder my charger port on my battery but I want to be sure it would be safe this way. So because of pre soldered wires on my fuse and bms I do have a few different sizes of wire in my set up. Would this be safe like the picture below (if itâs clear enough:p) ? (Those different sizes of pen stand for the different sizes of the wires and the red round is the fuse and yellow stripes or xt30âs
22awg is pretty small. Voltage drop and heat is going to become an issue somewhere around 3-4A. That may prevent a full charge. If that could be upgraded to 14/16 or even 18 AWG that would be ideal.
Only pay attention to the smallest wire in the circuit, which here is 22AWG.
If youâre going to charge at 10A or less, that will probably work, but will work a lot better for 7A or less.
What size is the fuse? For example, if itâs a 7.5A fuse then the wire size is fine.
Also which jack? Many 5.5x2.1 barrel jacks often get warm at 4A and canât do over 5A. In that case, the 22AWG wire would not be the bottleneck.
Whatâs that now?? Link?
Stories gone ![]()
Fucking instagram
Is there any way to disable the stormcore push to start?
ftfy
Thx! Charge is rated for 4A and my fuse for 10A. I rather be safe than sorry, but I also wouldnât like to resolder my solder charger port (gx16-2), because with 16awg it would be kinda hard ![]()
Is there an odometer on Unity VESCs that I can access to see the recorded number of km? Not for the curren ride, all of them
No.
I havenât found a way from the app interface but it was a toggleable setting on the unity so the potential has to be there, right?
Id hope so. Im gonna try to put a fingerprint sensor in my board and im really trying to avoid getting an external antispark for that but I dont think ill have to if I can disable push to start.
Diagrams are necessary for properly solving any and all physics problems. Hence why I say Iâm not 100% without having made one to double check. Youâd be surprised what little things you can miss without one
