Agree 100%
My goto is the $80 S1 Retro Lifer which I usually wear — even though it’s sitting beside much more expensive helmets…
Any tips about getting more motor clearance? Its about 2cm off the ground, but I can’t put it higher because it touches the truck…
reverse mount it
Isn’t possible because my enclosure is too large
ohh wait that is reverse mounted Your motor mounts are super short then. longer mounts and maybe a truck riser would let you put it higher
Hmm I just have those motor mounts of dickhyo so I tought nothing special
is it me or what, i can’t tell which way the board is facing
ohh u need longer mount if u gonna rear mount the motor. that dickyho mount is meant for forward mount iirc, but he does have a longer mount which is made for rear mount
Thx didnt know that
u not able to forward mount it? ur enclosure in the way?
Yeah that’s impossible
oof
Will just do it with my 2cm clearance
2cm is 2cm, good enough for me
Dear system,
yes, i know
i’m running 1.5cm in nyc. you’ll be fiiineeee
Looks very possible with an enertion style mount
There is really a very little space for the mount, so when it succeeds I guess it will have 2cm clearance as well
Tbh I’m more concerned with hitting the truck than the ground in that specific setup, I still think you’d be better off mounting towards the enclosure for that reason. If it’s not already fixed in palace with loctite or you’re ok with cleaning and reapplying it I’d try it forward mounted to see how it is
