Got a space heater?
Good idea. Its rated for 13 amps though. How do I connect it without discharging the battery too much?
Also really good video on the DV6 ESC, so thanks for that.
At 48v a 120v space heater will only draw 5A on high (120v / 13A = 9.2Ī©. 48v / 9.2Ī© = 5.2A).
Monitor with a multi-meter and unplug it when itās at the voltage you want. Will probably take an hour or two depending on battery size and charge state.
There is also a battery discharge option in the metr app that uses the motor in foc_openloop
Yep this is what I would suggest. I havenāt actually tried it I just know people have before.
Discharging batts is always a trouble
thanks guys. Iāll give it a shot
Is the Rockstar II hubs prone to be unbalanced and can i balance them if they are?
Are aluminum hubs better or is it just for looks?
It is easier to achieve tight tolerances with machining than injection molding, so machined aluminum hubs are often better in terms of balance and fit. Not guaranteed, as there are both very good injection molders, and very bad machinists, but on average aluminum is better.
I have an s120 50.4v charger. The charger will work on other batteries but i have one battery where it charges to 48v and then flashes red/green.
The pacck had previously charged to 50.4, went for a ride, and now stuck at 48. Ive measured the p groups in the battery to be 4.06 +/- .02 without variance. Is the charger letting me know a cell is bad? Or could it possibly be a weak connection somewhere in the charging wiring? I have suspicion the cells are healthy as they charhed up to 50.4 the first time.
Thanks.
60V maximum ESC voltage. Does this mean 12s or 13s Li-Ion? Is there more to the difference than this?
12S
So why is this a thing?
I list the ratings the manufacturer gives on the details section of the product page.
The closer you run to the limits of the components, the less reliable it will be
Plenty of people have run 13s on 60v controllers, itās just a bigger risk
Is not using brakes for the first ~2V of discharge mitigate that risk? Are there other measures to mitigate the risk using 13s on a 60v ESC?
I did it with escapes and hummie hubs. Was always very ginger on the brakes for the first few kms.
Iād say trying to minimise voltage spikes is wise, iām sure there are a number of ways to do that.
Anyone have ideas on how to get this axle out? The hex is stripped.
I tried putting a nut on it with some green loctite to use the nut as a grip. But, when I heat up the axle the heat just radiates to the axle tip and loosens the green loctiteā¦
On another one of these axles I dremeled a slot for a flathead, but the metal is weirdly brittle and it doesnāt work very well.
Any ideas? Send help!
if u gonna destroy the axle in the process, might as well grind 2 flat spot opposite side of each other, then tighten it on a vise and start twisting the hanger?
any scrub screw take u might have missed?
took the grub screw out so thatās not it⦠think itās just extra tough to remove, maybe cause of the bend in the axle?
good idea grinding it and using a vice⦠may have to do that if I canāt figure out an easier solution lol
Pipe wrenches are literally designed for this, just have to find a small one. Theyāre designed to grab onto a smooth pipe and torque the shit out of it.
If you can get your hands on a set of Knipex Cobra pliers, they are basically a pipe wrench in pliers form. Highly recommended for gripping round things.
