Surf Rodz TKP trucks aren’t very stable without split angle baseplates, and they use bolts that snap under stress, so they kinda suck for esk8. Savage trucks are much better
That being said, you could ask for mystery surf rodz with a 10mm axle, buy longer replacement axles from boardnamics and Idea mounts for them. You can make it work if you really want to…
wouldnt it still be a gamble with regards to the hanger length? like if I land a 100mm hanger then I’d have to use loads of spacers so that wheels fit and even then it’d be risky? . My build is lightweight street build, only concrete friendly, so the lack of robustness for SR may be ok…though the wheels of choice will be Trampa hypa hubs/gummies/urban treads and maybe some blue cags (gonna sell my TB110 as they too heavy)
How do you mount 3 grub screws motor mounts an keep them straight?
I’ve got the feeling I tried everything I can (eyeballing it, pressing it against the pulley then tightening, different tightening patterns, edit: also tried to use threaded rods to adjust them parallel and then tightening, same result) but they either don’t mount perfectly straight or they wiggle themself free after some paved roads even with 243 loctite on them, I’m 2 clicks away from ordering BN184 and precision clamps (tho that would mean I also have to get plates laser cut to fit my lights…)
The worst is, My first board was with this type of mount I made, ended up welding them in place, I swore never to use grub screws again. But I’m an idiot.
