That is unfortunate ![]()
Iāve had way too many frustrating failures with that type of clamping system. 2 piece clamps are the only way IMO.
No idea about those, but you can get 20 degree caliber baseplates from @Tony_Stark
Update to 1.1 and have disconnection issues ![]()
About 1.5 to 2 meters far from the board it disconnects.
Any help will be appreciated
Donāt mount them at all. Get some better mounts.
Even if you get them mounted, they will likely fail in short order.
That being said,
Looks like good positioning to me.
Worth checking with flipsky?
Thanks I saw your post about it and tried it, also didnāt do the job. Iām going to order some bn184 hangers, mounts and laser cut plates
Those will work wonderfully.
So switched on my board and hubs were just stuttering slowly and not spinning when I pressed the remote.
Iāve reset firmware on my Stomcore esc and when I run motor detection wheels spin like you would expect but when you check the direction immediately afterwards both wheels donāt spin just stutter a little.
Getting it started by hand doesnāt help and the detection wizard does detect the hall sensors.
I was going to unplug sensors and try again. Any other tips on what to look out for in this scenario? Or are there any settings or diagnosis steps I can take?
Thanks
try detection again, sometimes it just messes up, sometimes you have to try a couple times to get it right
Make sure your sensors are plugged in to the same side as your phases
I think this was it! I am still surprised as I am sure i had it working before and maybe when trying to resolve the issue I got them the wrong way round. Is there any issue with having the sensor cables tied together in the enclosure, like could you get interference having them all bundled together too tight?
Not too sure about that one. Iāve not personally had an issue, but I run the majority of my personal boards sensorless so not a great deal of experience there.
no sensors is king
The VX2 remote sees to always default in VESC Remote settings to Control Type Off with my Stormcore. Should I be setting this to Current or Current Bi-directional?
Or current no reverse
Sorry for all the questions but getting frustrated with this mod.
Just to recap Iāve swapped the shitty lingyi esc in my Bustin Sportster with a Stormcore 60D+.
Based on my charger voltage and it being advertised as 270wh Samsung battery Iāve deduced itās a 10s3p and likely Samsung 25R cells and used that to estimate my battery current max at 30amps per side and -15amps for Regen.
After having some problems with sensors Iāve decided to try sensorless for now.
I canāt seem to get my brakes to bring the board to a complete stop on even a gradual decline. Iāve tweaked the motor brake setting a few times and canāt feel any difference so wondering if itās my app settings.
Hereās the motor current settings:
Thatās normal for regen braking, the braking torque falls off asymptotically as you approach zero RPM. To actually ālockā the wheels on an incline you need to be actually injecting power into your motors to counteract the torque. The easiest way to do this is to use one of the control modes with reverse (either smart reverse, bidirectional, or plain ācurrentā).
Low speed braking (or no speed braking) is definitely one of the areas where having sensors is beneficial. HFI works too. The controller has trouble knowing the rotor position at low speed without sensors.
Thankyou, Iāll try and get the sensors working. I was getting one intermittently being a problem, may be wiring or cables getting caught in the enclosure.
I will try smart reverse too as well as those other control settings.
Do those Regen and motor brake settings look ok? The motor ones are the defaults after running detection
