sounds and seem about right, in the pic perspective it seemed bigger. Now what’s the lenght of it ? xD
btw I totally got my guess right
edit: no you didn’t see that
now I’m really wondering if I need to use a BMS… I think I will give them a couple of cycles on a board and see how they do.
I guess they don’t really need it but going back and manually balancing them after they do get messed up is a pretty big pain so that is the balance.
better be safe than sorry
The solution is external BMS with some kind of connector…
the solution is to change the connector
what connector? I’m talking about a solution like this:
ooooh yeah I thought you were talking about the original one
Weld…weld away
awww I wanted to ride them… Already have good weld packs that were much cheaper.
tbh should have reconsidered before purchasing.
600AMP ?? 4WD offroad board at like 20 000 watts xD
go kart with a starter motor
Can someone get my credit card away form me ? I still need 2 or 3 more boxes tho :’)
Edit: at least I don’t pay Taxes on it
haha yeah 10Ah is just a bit low for a power hungry board like that, plus one gives enough amps on it’s own. IDK I am thinking like use each 5Ah 12S1P pack for some kind of racing machine given the power to weight is really good. I need a 20A 12S charger…
With that you can make a limitedable 50A 12s charger.
Really once you’re around 15A, charging is entirely limited by thermals. So then it comes down to good cells and welds
[details=" a box was in the box, how original"
[/details]
I use 12S LiFePO4
