AWD “Displacer” suspension board
“There is no replacement for displacement” was the motto for this build. Heavily inspire by Psychoframe by @NoWind , once I saw it, I knew I had to build something similar with a focus more towards road riding.
This board features a metal construction with pieces cut by Sendcutsend and welded together by me. The two swing arms at each end allow the truck angle to remain the same throughout the shock travel. There is about 2 inches of travel now with even more travel planned down the line. The shocks are 150mm with rebound/compression adjustment. The tires are 10-inch Kendas.
The trucks are similar design to Liquid Fyre trucks with two pivots at each end of the hanger. This makes the trucks precise and allows you to run soft bushings. I’m running wfb tall fatcones with bigger end towards the hanger, this gives a strong center and a deep carve while riding. The angles are 45/30. These turned way better than I had hoped and make RKP feel unrideable in comparison.
I really like it so far, this platform has so much potential. A big part of building this board is my right knee (goofy stance) is not 100%. Riding E-boards has really taken a toll due to high impact on joints, especially at higher speeds. I have been easing back into skating after a couple of months hiatus and hoping this board can take me out of retirement basically. An X-ray did not show any obvious injury so that is good… What I recommend to my fellow riders is to stay away from stiff decks, (rode a CF deck, got rid of it asap), use big tires, and maintain a healthy weight. Going slow also helps, but ain’t nobody got time for that.
There are so many ways to design a board with suspension, different geometry, suspension travel, parts, materials. I would like to see what other people can come up with. There is room for improvement in this design. This build was a proof of concept for me, and I see areas where I would like to improve, mainly the overall weight of the board. I think this style of board is the direction we need to be heading in, even if my old school mentality might not want to agree.
