Perfect, that’s exactly what i was looking for. Thank you
Do you have a link to your monster by any chance ?
Thank you, it’s nice to see that i’m starting to understant stuff ^^
I would recommend it unless you have heaps of space i am goung to have to reengineer it so heat sink is external to enclosure this baby heats up fast the 4 amp must use a super efficent buck its happy to sit in a sealed enclosure with just a raspberry pi 3 headsink add putting out close to 4 amps. I will dig up the link from my banggood emails. I need 8 amps to drive my rgb matrix display so I am hoping 1/2 brightness and avoiding gifs with lots of white will only draw 4 amps. As i need the other 3a for esp32 to run display and control side ws2812 strips talt to the vesc and do the brake lights. Couldnt find on banggood but here is a similar unit on ebay at 4 amps the heatsinks get hot recommend bigger heatsink and maybe fan mine came with an enclosure and was nearly twice : ( you got me thinking I may be better off using 2 x 4a bucks instead)
Holly shit that’s not a skate, it’s a full imax. Don’t bother with the link i found some stuff on ali express that fits my needs. It was a few clicks away in recommended products in the link you gave me. Big thanks to you .
I question my sanity on this build slash experiment its not going to be a every day board. Lucky it has a 32 amp battery.
Huhu, that’s the kind of stuff i want to do, over the top absolutely useless but enjoyable.
I’ll probably do the same 2x5A, cheaper and more manageable heat and space wise.
I looked a this, but, no, just no :
#DC-DC Buck Module 12 V-72 V à 0-60 V 12A
https://fr.aliexpress.com/item/32864339539.html
Yeah I had a semi when I saw the specs then when I saw it…there is an exponential correlation with amps and how ridicules the cooling has to be. I also have a hobbyking buck on order too. but 2 x 4a might be the simplist solution.
How much does your board weigh…My setup seems like it’s about 50+ lbs.
If I have two single 4.12 vescs connected via CAN bus, can I use both uart ports? One for the remote and one for a davega display?
There are some extremely compact and highly efficient DC-DC converter modules out there designed for railway applications and the like, such as this tiny monster. 18-72v in, 5v 10a out, and up to 91% efficiency.
It’s even cheaper than that aliexpress item you linked, at a fraction of the size - 33.0 x 22.8 x 9.5mm.
Is the vesc-project page working for people? It’s completely dead for me. If possible, can someone direct me to some other firmware versions?
This what you’re looking for?
Thank you! But also on a separate note, is vesc-project down and if so why?
Not loading for me either. Maybe maintenance or something.
Thanks for confirming! I think it’s been down all day. I tried earlier this morning and still nothing
If you are looking for Vedder version 4.1 and OS Linux, then I have a copy.
I also have Ackmaniac 2.54 for Windows and Linux and mac something
I also have Ackmaniac 3.103 for Windows (the Linux version is broken)
I mean if the site is down and you need something now.
we need a repository here
You can also go to github and download the source and compile it yourself but that takes longer than asking for it.
Oh here is Ack 3.102 built for Linux
