Well I am a bit dumb sometimes so I need your help.
I was changing my evolve connectors on the motor and esc and I forgot to take a picture to know which phase wires connects to which one.
The motor has black, yellow, Red and the wires from the Esc green, blue, yellow.
Can someone with an evolve board or the knowledge tell me?
Paging @b264@Hogyoku@Posterduck
also I did not think this as a problem at the time.
The evolve esc uses an mt30 and 18awg wires, is it an issue to change the connector to an mr60 and wires to 16awg?
Sometimes when I press the “reply” button on a post, the text box comes up and it shows the person I am replying to in the top of the text box, but when hit the orange “reply” button in the text box my post is not posted as a reply. Anyone know what I am doing wrong? On mobile, if that matters.
(P.S. take a shot every time I say “post” or “reply” )
This is normal if the person you are replying to is the last post, for example right now i am “replying” to you but it won’t show your profile pic on the top right because you are the last post. If i replied to @Venom121212 then it will show that i am replying to him since there are posts in between your reply and the original comment
The 2 red arrow bolts take up the spring holes but are holding up the green arrow bar that holds the shock blocks in place. If you remove that bar and those bolts, it looks very similar.
Also makes me wonder why they went away from that, to nylon, and then to a different metal design…
Think usually a sign things aren’t getting hot enough for everything to go molten so you are just layering molten layers on solid layers and making the “ripples”, so maybe just need to go bigger tip or hotter iron to make sure everything is going molten, you want the pads the solder is flowing onto to be “wet” which is to say the copper on the surface is flowing along with the solder and so it becomes one alloy basically in the end.
Right, i was on 400*C and had a large tip (c4 i think, not sure about the names. All flat on the end) so not much i can do
But does this look bad?
Should i redo it.
It definitely isn’t a cold joint since it is shiny like a mirror
