Sometimes,
a little force is needed.
LoL ninjaâd by @Kellag
rubber mallet & arbor press, fix so many problems.
I prefer a hammer and a wood block over a rubber mallet, but mostly the same
The wood you can pre-position in a certain place before you whack the shit out of it. The mallet relies on aim while whacking
@Kellag wasnât sure if i would damage the core with that. But why is it that it easily fits on the other side?
@b264 Will try tomorrow! Thanks
Whether the kegel cores are âforwardâ or âreverseâ inside the polyurethane affects how pulleys fit. The inside of the core will have a narrower part where the core itself had a mold seam during manufacture; that seam on the inside is âforwardâ and on the outside is âreverseâ kegel core.
Motto for most aspects of my life
Whatâs the JST type for CAN bus cables? (Or does anyone have one they wanna send me )
JST PH 2.00mm.
edit; where you from, if youre in NA ill send you a couple.
Delaware, sacrificed the one on my MTB for someone
Edit: donât worry about it, they are literally $2 for 10 on Amazon
Edit 2: NVM, doesnât arrive for a month
Is this the best way to incorporate the volt meter? And ensure it will only be on when the board is connected (antispark plugged in)
Splicing it into the cables
Normally the negative is connected to everything and the positive has the loop key: you want the bolt meter on the same side of the loop key as the esc
@Arzamenable and I know little about dog tits. Excluding supernumary freak shows, how many titties do dogs have? Mike says 8, I say 10. Help us solve this mystery.
Great to see you here and have bumped you a level for surviving association with the doctor.
Welcome!
Well shit, now she knows our secrets. 8 titties for the record. Kalia wonât let me look at his nips bc heâs 140lbs.
Glad to be here
Based on this wouldnât the volt meter always be on
Edit: just thought about it a bit more and realized no it wonât
Can I run BLDC on a focbox unity? Thatâs the dealbreaker, I love BLDC
I donât have one, but since itâs basically just a vesc, and their software is (to my limited knowledge) just a skinned version of vesc tool, you should be able to.
You may need to use the non-unity version of vesc tool though.
